Save $13 and keep your battery topped off with this Qi wireless charging pad
The Kuulaa USB-C Qi wireless charging pad white is down to $7 with code ZX3IYGXN on Amazon. Without the code, the charging pad is selling for $20. It always sells at that price, and we haven't ever seen it drop this low directly. In the past, the most likely way this pad ever saw a drop in price was through a code like this, but even then it didn't drop this low.
Provides 7.5W for iPhone and 10W for Android phones and 5W for other Qi-enabled devices. Has safety features to protect from overvoltage, overcurrent, overheating, and other issues. Works with Quick Charge 3.0 if you have the right adapter.
Kuulaa Right-Angled USB-C Cable, 2-pack
$6.30 $13.99 Save $8
Kuulaa's USB-C cables are each 3.3-feet long, suitable for charging and data transfers, and down to around $3 apiece using the following promo code at Amazon. That code also works for the 6.6-feet cables, taking $10 off.
Kuulaa 10W Qi Wireless Charging Stand
$10.99 $19.99 Save $9
This stand offers up to 10W fast charging for compatible devices, along with safety protections to keep your phone safe from overcharging, overheating, and more.
Kuulaa Wired Headphones
$4.39 $10.99 Save $7
Sometimes, you just need the wires. These headphones have an in-line mic so you can make and receive phone calls, and offer a powerful yet balanced sound for listening to music. Clip the on-page coupon and use the promo code at checkout.
Rock Right-Angled USB-C Cable (2-pack)
$6.99 $13.98 Save $7
The unique design allows the cable to sit behind your phone as it charges so you can keep using it without holding it in an odd position. Use the code on either the 3.3ft or 6.6ft version to score either 2-pack at 50% off.
$11.54 $19.99 Save $8
This Qi wireless charging stand charges compatible devices at up to 10W and can even charge through phone cases. You'll just need to enter the following code at checkout to score this low price.
The pad will provide you 7.5W fast charging for the iPhone from the 8 Plus and up. It will also provide 10W fast charging for the Galaxy S10 lineup, the Note lineup, and more. Other devices get 5W as long as they are Qi compatible.
It is designed with a zinc alloy that makes the bottom surface smooth and wear-resistant. It uses a non-slip silicone design so phones won't slip and slide across the pad. With the white color, the simple design, and the slim appearance, it's a stylish charging pad that will fit in a multitude of situations. The pad also has a smart white LED that will let you know when it's ready to charge, when it's actually charging, and when the device it's charging is ready to go. The charging function should work up to 8mm, which means you can use even a thicker case on your phone and still get the power you need.
If you want to get the full 10W charge on your Android phone, you will need to connect to a Quick Charge 3.0 wall adapter. Grab this one from Anker for just $13.99.
The Kuulaa pad has plenty of safety protections. You won't have to worry about the pad or your device taking this whole wireless charging thing too far. The pad will keep your device safe from things like over-heating, over-current, short circuiting, and more. It won't over charge your battery or waste energy unnecessarily.
John Levite
