The Anker PowerCore 13000mAh 2-port compact portable charger has dropped to a sale price of $24.99 on Amazon today only. The low price is part of Amazon's Gold Box deals of the day, so it's very temporary. Usually this power bank is sold directly by Anker for around $38. We have never seen it go this low directly, and the last sale was a drop to $30 back in January.
Unfortunately the sale price only applies to the black colored charger as the other others, like Blue are still selling at the regular $38 street price. You can see how good this price is by just looking at some of Anker's other options. Even a slight upgrade to the 15000mAh battery charger would cost $15 more.
Always Be Charged
Anker PowerCore 13000 Portable Charger
With 13000mAh of internal battery life this will charge most new phones up to 5 times, and some even more. It has two USB outputs for charging multiple devices at once, and it recharges via microUSB.
$24.99 $35.99 $11 off
The 13000mAh battery is a large capacity and capable of charging all your smartphones several times over. Plug in any compatible devices using the two high-speed USB-A ports. Since both ports use PowerIQ and Voltage Boost technology, they will be able to detect exactly what device is plugged in and adjust accordingly. You'll always get the fastest possible speed for whatever device you're using, although the charger does not support things like Quick Charge.
Get an iPhone SE with Mint Mobile service for $30/mo
It is also designed to be compact and portable, so you can fit it into your purse or backpack. The whole thing is only the size of a wallet, and it comes with a travel pouch. You'll get a micro USB cable for charging the device, and it's backed up by Anker's 18-month warranty. Users give it 4.6 stars out of 5 based on 7,267 reviews.
