Store up to 4TB with Seagate's Backup Plus USB 3.0 Portable Hard Drive on sale for $75
Woot has the Seagate Backup Plus 4TB USB 3.0 Portable External Hard Drive on sale for just $75 today in your choice of Red or Silver. That's lower than either of them has reached at Amazon, where they're sold for $110 and $120 on average, respectively.
Shipping at Woot is free for Amazon Prime members; you can start a free 30-day trial today if you're not a member yet or be stuck paying Woot's $6 shipping fee.
Keep all your data safe with this discounted 4TB USB 3.0 external hard drive from Seagate at one of its lowest prices in history!
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
The Seagate Backup Plus is one of the best hard drives out there despite having been around for a couple years now. In fact, it's still an Editor's Choice top pick at PC Mag because it's fast, simple, and easy to use. Four terabytes is also a lot of space to mess around with, and the drive works with both Mac and Windows computers without needing to reformat. It's covered by a two-year warranty.
A purchase of this drive also comes with two free months of Adobe's Creative Cloud Photography plan giving you unrestricted access to Photoshop and Lightroom.
