Apple's Lighting cables aren't particularly hard-wearing. If you spend any time travelling with your cables or even if you just like to use your devices while plugged in at home, you'll probably find that they get crumpled and frayed, and eventually stop working. Rather than replacing your cable every few months, why not invest in a more durable option like this Premium Double-Braided Nylon cable from Anker? It usually sells for $12 but drops to just $8.49 when you use code CABLE815 during checkout. The code works on the black and red versions.
⚡️ and 🔄
Anker Premium Double-Braided Nylon Lightning Cable
Stop replacing your Lightning cables every few months when they get all frayed and damaged. Instead, stock up on durable, MFi Anker cables with and use code CABLE815 at checkout to drop them down to $8.49 each.
$8.49 $11.99 $3.50 off
The highly-rated 3.3-foot cable is MFi-certified so will work perfectly with your iPhone or iPad and can charge and sync your device just as well as Apple's own-brand cable — and costs less. It features a braided nylon construction complete with unibody connectors so it is resistant to damage from normal usage. Its rugged design means it will last five times longer than your generic Lighting cables, meaning you won't have to keep buying new ones. Anker is so confident that these cables can withstand the test of time that it backs them up with a lifetime warranty.
