Clip a coupon to save $50 on this APC 1100VA battery backup
The APC Back-UPS Pro 1100VA Battery Backup & Surge Protector (opens in new tab) usually costs around $170, but today you can head to B&H and clip the on-page coupon to nab one for only $119.99 shipped. That's the best deal we've ever posted for this particular model, which is only discounted for a limited time.
Image (opens in new tab)
Keep your gear protected from power surges and failures and give yourself enough time to save your data and shut it down in an emergency.
An uninterruptible power supply guarantees protection from power surges or lightning strikes. APC is so sure it'll keep your equipment safe there's a lifetime equipment protection policy where APC will replace properly connected equipment that is damaged by a power surge.
The UPS also acts as a backup battery in case the power completely goes out. How long the battery lasts depends on how much stuff you've got plugged in, but it is powerful enough that even if your most powerful electronics are plugged in, like a desktop computer, you should get at least enough time to save everything you're working on and shut down safely. If you aren't drawing too much power, the battery could last much longer.
This device has eight outlets with surge protection, with six of them connected to the battery backup. It also has an automatic self-test to determine when the battery might be failing and will let you know with notifications when that's going to happen. There's nothing worse than a battery backup that fails when you need it most, but luckily the battery is easy to replace. The system uses audible alarms to let you know when there's a change in power or when a component might be failing. Your purchase includes a three-year warranty as well.
