Amazon has the Aukey B80 Bluetooth high-fidelity water-resistant earbuds on sale for $43.99 thanks to the code RXVKB2FJ and an $8 off on-page coupon.The earbuds normally sell for around $70 but are currently $80 without these discounts. Either way, today's deal is easily the lowest we've seen.
Sounds like a Deal
Aukey B80 Bluetooth earbuds
Don't forget the on-page coupon as well as the coupon code. They stack and give you a much larger discount.
$43.99 $70 $16 off
With coupon: RXVKB2FJ
The Aukey B80 just became available on Amazon in March, so this might be the first real discount they've ever had. The headphones use high-resolution audio with a hybrid driver system that are precisely tuned for balance and generate richer sounds. They also have Bluetooth 5 with aptX low-latency tech, USB-C charging, water resistance, and more. With the USB-C charging you can spend 10 minutes juicing up to get 80 minutes of playback or get the full eight hour playback when fully charged. The over-ear hooks provide a comfortable fit with out-of-the-way convenient cable routing. You'll also get Aukey's two-year warranty.
Switch to Verizon and get an unlimited plan to save up to $700 on a new iPhone
Cyber Monday!
