Aukey's compact QC 3.0 USB wall charger can fast charge devices for less than $12
You probably already have a few standard USB wall chargers at home, but with Aukey's Dual-Port Quick Charge 3.0 USB Wall Charger, you could power up your devices much more efficiently, and affordably too. While this charger normally sells for $19.99 at Amazon, using code ULIPLJJ2 during checkout will drop its price down to $11.99 for a limited time.
Compatible devices can charge up to four times faster using this tiny USB charger. You'll just need to use code ULIPLJJ2 during checkout to score this 40% discount.
$11.99 $19.99 $8 Off
This wall charger is equipped with two Quick Charge 3.0 USB ports that can charge compatible devices up to four times faster than standard chargers can. Devices which aren't QC-compatible can still be charged with it, but at up to 2.4A. There are even built-in safety features to protect your devices against overheating, excessive current, and overcharging. Plus, Aukey includes a 2-year warranty just in case you need a replacement.
It's well-reviewed at Amazon too, featuring a rating of 4.3 out of 5 stars based on nearly 1,600 reviews.
