Stock up on AUKEY's durable braided nylon Lightning cables with two at just $4 apiece
If you're in need of a new charging cable for your iPhone or iPad, you can save on two of AUKEY's Apple MFi-certified Lightning cables at Amazon when you enter promo code H2OAQ5VJ during checkout. This two-pack of right-angled Lightning to USB cables falls to $7.94 with that code, taking the price of each one down to under $4.
AUKEY Right-Angle 3.3-Foot Lightning Cable 2-Pack
The right angle means these won't get in the way of your hands while you're charging your device. These cables are durable, MFi-certified, and down to one of the best prices ever. Don't forget to enter the coupon code to save!
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
The cables you'll receive are each 3.3-feet long and are designed with a special 90-degree connector that helps keep your cord out of your way while charging your device. That means you can continue to use your iPhone or iPad for gaming or watching video and reduce stress on the cable itself so it should last longer.
Speaking of durability, the cables are made of braided nylon and have zinc alloy connector housings. They can sync as well as charge your device, offering transfer speeds up to 480Mbps, and are compatible with every Lightning-enabled Apple device thanks to MFi certification. The two-pack contains one red cable and one black cable and AUKEY backs them up with a 24-month warranty.
Adam Oram
