The Eufy security eufyCam E wireless home security 1080p 1-camera system is down to a ridiculously low price of $179.99. This deal is thanks to a standard price drop from $280 to $238, a $20 off on-page coupon, and the coupon code EUFYCC22 that takes off an extra $38. You're basically saving $100 and getting your foot in the door for 1080p home security.
Home security
Eufy Security EufyCam E wireless 1-camera kit
Start with the basic 1-camera kit here. Then add more cameras, larger microSD cards, and more as you get used to the system.
$179.99 $280 $100 off
With coupon: EUFYCC22
This 100% wire-free camera system is IP65 weatherproof-rated and has an internal battery that can last for a full year on a single charge (or three years in standby mode). It films in 1080p resolution and features night vision as well so you can see anything going on outside no matter what time of day it is. And using the EufySecurity app, you'll be able to check in on the camera's video feed no matter where you are.
Switch to Verizon and get an unlimited plan to save up to $700 on a new iPhone
Unlike other security systems, the eufyCam E doesn't require that you pay for a monthly service to use it. A 16GB microSD card is included with its purchase so you can store up to a year of recordings without needing anything extra, but the home base supports up to 128GB so you can upgrade for more room if you want to. You'll also receive mounting hardware so you can install it easily around your home.
If you're looking to add more cameras to your setup, you can do that at any time in the future for $179.99 per camera. The packages above also include the required base station that helps the cameras all work together seamlessly, and it can support up to 16 total cameras.
Cyber Monday!
