It's time to gain better control in your home with the JACKYLED 9.8-foot USB Power Strip Surge Protector. Unlike most of the power strips you'd find in brick-and-mortar stores, and most of the ones you likely have at home, this power strip is equipped with four high-speed USB charging ports that can power devices up to 2.1A without needing an extra USB wall charger plugged in. It has six standard AC outlets that are well spaced out too, so you won't have to worry about bulky plugs getting in the way of others. Today you're in luck as using code RJWW2VZ8 during checkout at Amazon will bring it down to $16.49, saving you $9 off its current price; it sells for around $24 on average there.
Take Charge
JACKYLED's USB Power Strip doubles as a surge protector, featuring six AC outlets and four USB ports. While it normally sells for just under $24 on average, using the code below can save you $7 off that cost.
$16.49 $23.71 $7 Off
With coupon: RJWW2VZ8
This surge protector features a flat, right-angled plug which makes it easier to plug into sockets in tight spaces or behind furniture. There's also a 10-foot extension cord to give you some extra room for its placement. Plus, JACKYLED has integrated protections against power surges, lightning strikes, overloads, and more. It even automatically cuts off power to connected devices when over-current is detected.
At Amazon, more than 300 customers left a review resulting in a rating of 4.4 out of 5 stars.
