Woot is offering the Linksys Velop Mesh Wi-Fi Router 2-pack for just $289.99 today only. The bundle sells for around $340 at Amazon so you're saving $50 with this deal. The 2-pack is offered in new condition and carries a lifetime Linksys warranty. Shipping is free for Amazon Prime members.
Get meshy
Linksys Velop Mesh Wi-Fi Router, 2-pack
Replace your router with these and be amazed at the Wi-Fi coverage. The $50 savings is good for one day only, though.
$289.99 $340 $50 off
You'll get two Tri-band Wi-Fi router replacements, which connect to your existing modem and blanket your whole home in a strong network. These bad boys can cover up to 4,000 square feet, so they're perfect for multi-story homes. They're compatible with any ISP and easy to set up through the free Linksys App. That app also grants you access to parental controls, special guest Wi-Fi, and more. The devices work together, too. If one loses signal, the other units will automatically re-establish connection. The whole thing is designed to be sleek and ultra-compact, with the antenna built into the top of the device and no excess wires. For a minimalist footprint, you might want to check out a wall mount too.
Over 2,100 customer reviews left this with an average of 4.2 out of 5 stars.
