ORICO's $22 transparent USB hub adds seven ports to your setup
Amazon has the ORICO 7-Port Transparent USB 3.0 Hub available for $21.59 when you apply promo code JFVVX53I during checkout. We've seen its 4-port version drop to $18 before, so this is an excellent deal that provides even more connectivity options. Shipping is free with Amazon Prime or on orders totaling at least $25.
ORICO's USB 3.0 Hub can power and charge devices, transfer data, and even glows blue when in use.
Equipped with seven USB 3.0 ports, this transparent hub lets you turn one USB port into seven with data transfer speeds up to 5Gbps. Whether you want to plug in a mouse, keyboard, an external hard drive, or a charging cable, this hub can handle the task and even glows blue when a device is connected. It features a VL817 intelligent chip to power, charge, or transfer data efficiently as needed, and it's compatible with use on Windows, Mac, and Linux computers.
ORICO backs up this USB hub with an 18-month warranty and lifetime technical support.
