This tiny 128GB SanDisk Ultra Fit flash drive is down to one of its best prices yet
Right now you can pick up one of SanDisk's insanely small 128GB USB 3.0 Ultra Fit flash drives for just $24.99, which happens to be one of its best prices yet. Normally, this drive sells for around $30 on average.
SanDisk 128GB Ultra Fit Flash Drive
Don't let its size fool you, this tiny drive can hold up to 128GB of your files without any worries.
Being a USB 3.0 flash drive means that you'll get high-speed data transfers when putting media and files on the drive and taking them off. It's small enough that you can plug it into your computer and leave it there, without even worrying.
It almost looks built into the computer once plugged in, and you can use the SanDisk SecureAccess software to help keep your personal files secure.
