While most wireless charging pads keep your phone laying down flat which can be inconvenient to use at the same time, Seneo's fast charging Qi wireless charging stand keeps your phone standing at an angle so you can still answer calls, surf the web, or watch a movie while it's charging. Though it's currently priced at $19.99 on Amazon, adding it to your cart via this link allows you to make an $8 saving during checkout. That takes 40% off and brings it down to the lowest price we've seen for it yet. If the discount doesn't apply automatically at checkout, enter code 40UH79HF for the same end result.
Get the juice
Seneo Qi Wireless Charging Stand
Keep your phone propped up in portrait or landscape while charging wirelessly. It supports 7.5W or 10W charging for devices that can handle it so you can get the juice quicker. Using the below link should apply the discount automatically during checkout, but you can manually enter the code if not.
$11.99 $19.99 $8 off
With coupon: 40UH79HF
This charger comes equipped with a USB-A to USB-C cable but no AC adapter is included with your purchase, so you may want to add one to your order today. Your phone will only charge as fast as the adapter allows, for the record. So if you want to charge an Android phone with QC 3.0 tech, you need a QC 3.0 adapter like this one.
Seneo's wireless charger works with most Qi-enabled devices including the newest slate of Apple's iPhone and various Samsung Galaxy phones. It's backed by a three-year warranty and has a rating of 4.1 out of 5 stars at Amazon based on 185 reviews.
