Skip to main content
Switch between USB-A and C with the $17 SanDisk Ultra 64GB flash drive
The SanDisk Ultra 64GB USB-C dual drive (opens in new tab) is down to $16.99 on Amazon. The drive normally sells for around $20, and it has never dropped this low before. The drive has been steadily dropping over the course of the year because it was high as $24 in July.
Other versions of the drive are also down to low prices. The 32GB version (opens in new tab) is less than $13 right now compared to its regular price of $15 or more. The 128GB version (opens in new tab) used to sell as high as $40 but is currently down to $32.
This dual-sided drive has a USB-A port on one side and a USB-C port on the other. That's convenient because it means you can connect to multiple devices, including those without USB-C. It also means you can read and transfer between mobile devices that use USB-C and larger devices like a laptop or desktop. The drive has read speeds up to 150 MB/s and is compatible with most platforms, including both Windows and Mac operating systems. Users give it 3.9 stars based on 875 reviews (opens in new tab).
See on Amazon (opens in new tab)
