Grab a few Syncwire Lightning Cables for just $7 each
This Syncwire 3-foot Lightning cable is down to $6.99 with code Y2EHGGXC on Amazon. This cable sells for $10 and it is never discounted except through similar coupon code deals. This code doesn't work on the other colors.
At this price, it's worth stocking up a bit. If you've noticed the cable in your car is starting to fray a bit or maybe you want to add a cable to your bedroom, you could buy a couple at a discount now and save yourself some money down the road.
Features include:
  • Unparalleled Durable Apple Charger - Holds over 30,000 cycles of 90-degree bend tests and hold up to 275 Pounds / 125kg in lab which is 30 times stronger than original device cables.
  • Certified Safe Lightning Cable - Approved for MFi, UL-FCC-CE certification and strict quality control ensure that your Apple devices are loaded safely at maximum speed.
  • Compatible with dozens of Apple devices
  • Extremely Flexible iPhone Charger - All of its interior wires are wrapped to prevent friction or fraying, and its exterior shell has a smooth finish to prevent it from getting snagged or ripped. Laser-welded connectors ensure superior functionality under heavy usage.
  • Premium Support - Friendly warranty support without any other costs needed. Fast and easy-to-reach Customer Service to solve your problems within 24 hours.
This cable has 4.6 stars based on 5,483 user reviews.
See on Amazon
John Levite
