Source: Honeywell
Best Ceiling Fans with Lights iMore 2021
While fans have a very functional role, ceiling fans with lights add a touch of modernity to your space. Having a fan and light installed as a unit will spruce up any room while reducing the need to crank up your AC system. With several fan options in the market, our favorite ceiling fan with lights is the Hunter Fan Key Biscayne Collection Ceiling Fan. It features a 3-speed motor with a reversible airflow feature.
- Best Overall: Hunter Fan Key Biscayne Collection Ceiling Fan
- Best Low Profile: The Harbor Breeze Mazon Ceiling Fan
- Best Vintage Design: Honeywell Sabal Palm Ceiling Fan
- Best Contemporary: Possini Vengeance Chrome Ceiling Fan
- Best Value: Honeywell 50195 Rio 54" Ceiling Fan
Source: Hunter Fans
What makes this fan a great pick is the versatility it offers. The blades are crafted from Barnwood and given a drifted oak finish. Combing such a rustic finish and a lantern-like light kit brings a maritime feel to any space. The fan's hardware includes stainless steel, which makes it ideal for both indoor and outdoor use. It is a good pick for both traditional and modern decor concepts.
It comes with a 3-speed ultra-quiet motor that moves air with power and peak efficiency. The blades have a 13-degree pitch for ideal air movement. Since the motor is reversible, the blades can move clockwise during winter for warm air circulation. The lighting kit comes with two longlasting 14W CFL bulbs that add a nice glow to any room.
The fan comes with three installation choices — a close mount for low ceilings, a downrod for high ceilings, and an option for angled ceilings. For quick ON/OFF functions, a pull switch is included. The fan doesn't come with a remote, but it is compatible with Hunter's remotes and wall controls sold separately.
Pros:
- Whisper-quiet yet powerful motor
- Optimized for both indoor and outdoor use
- The lights are quite bright
- The design blends with most home decor preferences
Cons:
- You will need to purchase a remote separately
Source: Harbor Breeze
The Harbor Breeze Mazon 44-inch fan features a compact, unique, and stylish design. It spots three reversible blades with a silver or espresso finish, a perfect complement for modern decor. Measuring 44 inches, it is a good fit for medium to small rooms and offices up to 100 square feet.
Alongside the fan, you get a light kit. The kit includes a dimmable LED 18-watt light tab and a matte opal glass lens. On the brightest light setting, you get 600 lumens and 3,000k in color temperature.
The fan's blades are pitched at 16 degrees for perfect airflow up to about 2,800 CFM. Using a remote, it is easy to control the 3-blade speeds and maintain a comfortable degree of airflow. Unluckily, it comes with a hugger/flush mount option only, which is the ideal option for low ceilings.
Pros:
- Ideal for both cold and hot seasons
- It comes with a remote and a wall-mount cradle
- Impeccable design to complement modern decor
- It has a powerful yet quiet motor
Cons:
- Suited for small to medium-sized rooms
- For indoor use only
Source: Honeywell
What better way to have a blast from the past than using the Honeywell Sabal Palm Ceiling Fan? Each of the four blades is handcrafted from basswood and given a beautiful brass finish. Each blade accentuates the unique design of a leaf and the surface polished to a wood grain texture. This is an exceptionally beautiful ceiling fan, both in color and design.
The lighting kit has a Tuscan sand glass bowl light and two E26/A15 bulbs. For added customization, you can switch the glass bowl with a better one. The fan comes with traditional pull chains for quick ON/OFF functions. But then, it is compatible with Honeywell ceiling fan remotes sold separately.
Running the fan is an ultra-quiet reversible motor with three air circulation speeds. During winter, you can reverse blade rotations for a warmer ambiance. It comes with three mounting options, a close mount, angled mount, and hang from a downrod. The fan is a perfect fit for medium to large rooms and offices measuring 350- 450 sq.ft.
Pros:
- The blades are carefully handcrafted
- The overall design is detailed and elegant.
- It has three mounting options
- The motor is whisper-quite and reversible
Cons:
- The lighting kit is a bit dim
- You will have to buy a remote separately
Source: Amazon
Contemporary ceilings fans feature sleek and clean-cut designs that blend with modern decor. The Vengeance Modern Ceiling Fan presents a stunning clean-cut metallic design with pitched blades. The fan's motor and blades spot a sleek chrome and silver finishing, which compliments contemporary interior decor.
The integrated light kit comes with three adjustable 6-watt LED bulbs. Their maximum color temperature is 3,000k, and brightness stands at 1300 lumens. A six-inch installation downrod is included. For higher ceilings, you can buy a longer downrod so that you fix the fan at a comfortable height. Also, the fan comes with a remote for controlling reverse airflow and blade speed.
Pros:
- Adjustable LED lights
- Cutting-edge modern design
- Variable downrod height
- Ideal for large spaces.
Cons:
- Lights cannot be turned off without the remote
- It is quite pricey to lack smart features.
Source: Honeywell
You will love this Honeywell Rio ceiling fan with matte black blades and a light kit. The kit includes two 13-watt CFL bulbs and a frosted glass bowl. Some people find the bulbs a bit deem, you can replace them with a brighter one or use the fan in the bedroom.
The blades have a decent 15 degrees pitch and span by a 3-speed reversible motor. A remote is included for easy control of the fan speed and light level. With the help of smart synch, you can activate the 'walk away light dimmer.' The fan comes with three mounting options; A close mount, a downrod, and an angled mounting option.
Even better, you can purchase a bond hub so that the fan works with Alexa for voice control.
Pros:
- Ideal for medium and large rooms
- With a Bond hub, the fans use voice controls
- Multiple mounting options
- Reversible motor
Cons:
- The light kit is not the brightest
Bottom line
For added convenience, modern ceiling fans come with a reversible airflow feature. They circulate cold air during the summer and warm air during winter. Depending on how bright the light kit, these fans can be used as the only source of light or to support existing light fixtures. Even more important, always know your ceiling height, mounting options, and the essential feature you could want from a fan with lights before purchase.
The Hunter Fan Key Biscayne Collection Ceiling Fan remains our best ceiling fan with lights. It is has a crafted oak finish that enables the fan to withstand humidity and moisture. The 3-speed motor runs in reverse during winter to circulate warm air. Also, the light kit design looks more like a lantern, which creates a rustic feel. The light kit is bright enough to be used as the sole source of light.
Grace Monene is an avid Tech Writer. If she is not reading, she is reviewing or testing new technology. She also probably tweets way too much
Quickly charge your new iPhone 12 with these fantastic USB-C wall adapters
The best iPhone 12 chargers will let you charge your iPhone super fast. If you plan on getting any of the newly-released iPhone 12 models, you'll want one of these chargers.
Every amiibo of every member of Mario's crew is here
Looking to complete your collection of Mushroom Kingdom collectibles? Here's every Mario amiibo available.
Take your Nintendo Switch Lite on the go with these great cases
Looking to take your Nintendo Switch Lite with you on a vacation or a business trip? Here are the best cases for the job.
