Best Hot Air Brushes iMore 2022
Hot air brushes dry and style your hair with one simple tool while giving you a voluminous, shiny, salon-look. Styling takes time and often leaves heat damage, but a hot air brush reduces all of that. The Revlon One-Step Hair Dryer & Volumizer Hot Air Brush will give you a salon-quality hairstyle with one easy product.
Best Overall: Revlon One-Step Hair Dryer & Volumizer Hot Air Brush
Tired of holding up a hairdryer and round brush for what feels like an eternity to get a salon-like blowout? Well, those days are over with the Revlon One-Step Hair Dryer & Volumizer Hot Air Brush. This styling product will brush, dry, and add volume while leaving your hair feeling silky and healthy. Featuring a built-in ION generator, this hot air brush will dry fast while reducing frizz and static for a smooth, conditioned look.
The unique features of this brush are what make it the all-around perfect choice. It has a lightweight, ergonomic design, Nylon Pin, and Tufted Bristles that gently grip and detangle hair. Plus, its oval shape helps achieve volume at the roots and curls at the ends. This hot air brush also features a ceramic coating and innovative airflow vents. These features promote faster drying and even heat distribution, so your hair is protected from over styling.
Built with the right amount of heat at 1100 Watts, you can place this hot airbrush closer to your scalp. Choose from the three heat/speed settings and achieve the perfect silky, smooth look. Not only will styling time be drastically reduced, but every day will look like you've come straight from the salon.
Pros:
  • Cuts hair styling time in half
  • Brushes, dries, and volumizes hair
  • Ionic technology
  • Reduces heat damage
Cons:
  • Not for short hair
  • May develop motor problems
Best Overall
All-in-one hair brush, dryer, and volumizer
Cut hair styling time in half while creating a salon-quality look.
Best Runner Up: Infinitipro by Conair Hot Air Spin Brush
__alt__
Take all the leg work out of perfecting a salon-quality hairstyle. Not only does this hot air brush comb and dry your hair, but the brush head spins to create voluminous curls! It will rotate in either direction giving you curl customization while creating a smooth and shiny look. Featuring ion technology, tangle-free antistatic bristles, and different heat seatings, your hair will be protected from damage.
Complete with two tourmaline ceramic spin brushes, one 2-inch, and the other 1.5-inch, you can create the perfect curl or wave that's perfect from day to night. This hot air brush also features a removable filter that allows you to clean lint easily and extends the life of the motor. Ready for a simple hairstyle solution? Go ahead, press and hold the button and rotate your way to impeccable curls.
Pros:
  • Spin airbrush
  • Creates voluminous curls
  • Shines while drying
  • Tangle-free bristles
Cons:
  • Brush doesn't spin on cool setting
Best Runner Up
Hot air brush with spinning head
Brush, dry, and create voluminous curls with one easy tool.
Best for Short Hair: Jinri 3-in-1 Hot Air Brush
Lightweight and practical, this hot airbrush features a 1.25-inch ceramic roll, which not only makes this styling tool better for short hair but prevents excessive drying and heat damage. With Nylon Pin and horsehair bristles, this 3-in-1 design detangles, dries, and volumizes hair while leaving it silky and healthy.
The ceramic technology helps to seal the moisture in your hair, which makes it super smooth and lustrous. Featuring two heat settings and 1,000 watts, your hair will dry quickly and evenly without damage. Now go ahead, create a stylish, radiant hairstyle in one easy step!
Pros:
  • Works on shorter hair
  • Ceramic technology
Cons:
  • Thinner brush may take longer to dry long hair
Best for Short Hair
Hot air brush for shorter hair
A 1.25-inch ceramic roll detangles, dries, and volumizes short hair.
Best Combo Kit: Conair 3-in-1 Tourmaline Ceramic Hot Air Brush Combo Kit
Featuring three different styling attachments, this hot air brush combo kit can help you perfect your ideal hairstyle with one simple tool. Snap-on the 1.25-inch tourmaline ceramic-coated thermal brush, which helps to eliminate static, frizz, and protects your hair from damage. You can also use the 0.75-inch natural boar and nylon bristle brush or the concentrator for ultimate styling.
The 3-in-1 hot air brush combo kit is complete with 1000 watts to complete your look faster while protecting from heat damage. Lock-on your favorite attachment and get a professional look that suits your day.
Pros:
  • Different attachments for different styling
  • Protects from heat damage
  • Eliminates static and frizz
Cons:
  • May be hard to hold
Best Combo Kit
Hot airbrush with three attachments
Achieve different salon-quality styles with one tool.
Best Budget-Friendly: Revlon Hot Air Brush Kit
Most styling products come at a cost. Luckily the Revlon Hot Air Brush Kit is super affordable while still offering quality. Complete with three different attachments, the 1-inch brush is for soft curls and waves, the 1.5-inch brush is for volume, and the smoothing concentrator is for precise drying. This hot air brush also features Ionic technology to reduce frizz and a ceramic coating to protect from hair damage.
There is an easy attachment release button so you can switch brushes quickly and achieve the perfect voluminous hairstyle with just the right amount of curl. Perfect for long and short hair, you can now get a salon-quality style at a budget-friendly cost!
Pros:
  • Affordable
  • Ionic Technology
  • Easy attachment release button
Cons:
  • On/off switch may be difficult to slide
Affordable hot air bush
A hot airbrush kit that dries and creates soft curls and waves.
Bottom line
A salon-quality blow out is often time-consuming and tiresome. These hot airbrushes are a simple solution to dry and style at the same time. They work amazingly on most types of hair; short or long, curly or straight, or thick or thin. Go from the shower to date night in half the time while achieving your best look and protecting your locks from heat. Now put down that clunky hairdryer and round brush and get smooth, shiny volume in one easy step with the Revlon One-Step Hair Dryer & Volumizer You won't ever use multiple hair tools again!
Author:
Courtney Reilly is a wife and mother of two beautiful babies. She is an avid writer who enjoys the challenge of turning any topic into a story. In her free time, you can find her hiking with her husband or spending time with her family.
