Skip to main content
Build ambient lighting behind your TV with Govee's USB-powered light strip on sale for $10
The Govee 9.8-foot USB-powered TV LED backlights light strip with remote (opens in new tab) is down to $9.74 with code OJDHCKQK on Amazon. That's a nice chunky discount of more than $5 off the price. We've never seen this light strip go on sale before, either.
(opens in new tab)
Bias lighting doesn't just make your TV look good and sync with your music, the strip can also help you with eye fatigue.
The light strip is 9.8 feet long and fits perfectly with televisions 46 to 60 inches long. You'll get colorful lighting that can sync to your TV. The remote control gives you access to change the colors from up to 32.8 feet away, and the control box is super convenient because it has only three buttons you need to control everything. With the built-in highly sensitive mic your light strip will sync with any ambient sound. While watching your favorite shows, the backlights will change colors and speed based on the rhythm. It also comes with six brightness levels so you can dim or brighten the lights as you see fit. The strip also helps reduce eye strain by decreasing the contract between your bright TV and the dark room around you.
