The Minger 6.56-feet TV Backlighting LED strip is down to $8.99 with code BN9Z2AGP on Amazon. This strip is $12 without the code and hasn't dropped this low directly before.
Set this strip up behind your TV or computer monitor to create a bias lighting effect, which helps create ambient light around the screen and reduce the strain of using monitors in dark rooms. It also has a built-in mic and special mode that allows the lights and colors to sync with any music you're playing. The strip is 6.56-feet long but can be cut on the marks to fit whatever size you need. The 3M adhesive attaches to most surfaces as well. It also comes with a portable controller. Users give it 4.2 stars based on 44 reviews.
See on Amazon
