Sunday's top deals: an LG Smart TV, the Razer mousepad, the Echo Show 5, and more!
We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
LG 65-inch 4K Smart TV - $699.99 (from $800)
The LG TV has a ton of smart features. It has Amazon Alexa and Google Assistant voice assistants built right into it, and they both work well with LG's ThinQ AI, which can listen, think, and answer your questions. The TV is also designed to work with Apple HomeKit, so you can use the Home app and Siri to control your TV or your larger smart home. Use any Apple device, including an Apple Watch or iPhone, to control your TV. Use any of the three voice assistants, along with LG's advanced intelligence, to search for your favorite shows, keep an eye on security camera feeds, dim the lights, and much more.
LG 65SM8600PUA Nano 8 series 65-inch Alexa 4K smart TV
Matches Best Buy as a deal-of-the-day. Has Alexa and Google Assistant built in. Supports Dolby Vision and Dolby Atmos for advanced images and sound. Uses NanoCell for vibrant colors. Also has AirPlay 2 so you can stream from Apple devices.
LG 27GL850-B 27-inch Ultragear Nano IPS G-Sync compatible gaming monitor
$386.99 $450.00 Save $63
The specifications include a 1440p pixel resolution, a 144Hz refresh rate, and a 1ms response time. With an IPS panel, you get great viewing angles and color accuracy. Plus the native adaptive sync works with AMD and Nvidia graphics cards.
LG OLED55CXPUA CX Series 55-inch 4K OLED Smart TV 2020 with Alexa
$1,350 + Free Speaker
Deal works with larger TVs, too. The CX series includes an advanced processor for 4K upscaling, LG's webOS smart platform that can access all of your favorite content and streaming platforms, features like G-Sync just for gamers, and more.
LG 27GN800-B 27-inch 1440p IPS Ultragear gaming monitor
$296.99 $400.00 Save $103
A great monitor that includes a 2560 x 1440 pixel resolution, a 144Hz refresh rate, and a 1ms response time. It has an IPS panel for great viewing angles. It's also G-Sync compatible with FreeSync native support.
LG 27GN800-B 27-inch UltraGear 1440p gaming monitor
$346.99 $462.00 Save $115
Add the monitor and an Xbox controller of any color to your cart and you should see $114 taken off when you go to checkout, giving you the controller for free and reducing the price of the monitor to $347, which is what it's going for elsewhere.
LG UltraGear 24GN600-B 24-inch 1080p IPS monitor
$179.99 $220.00 Save $40
This is a model unique to Costco. The monitor has an IPS panel for great color accuracy. It also has a 144Hz refresh rate and 1ms response time. Includes FreeSync, two HDMI ports, one DisplayPort, and wall mounting capability.
Razer Firefly Chroma mousepad - $34.99 (from $50)
The Firefly mousepad uses a hard, micro-textured finish that helps with both control and speed. The precise, consistant surface gives you great precision and complete control. Whatever mouse you use with whatever settings it has will only improve when used in conjunction with the Firefly mousepad.
Razer Firefly Chroma gaming mousepad
Uses a hard, micro-textured finish to help with both control and speed. The surface gives you precise and complete control regardless of your mouse or your sensitivity settings. You can customize the lighting underneath with 16.8 million options.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
Echo Show 5 2-pack - $89.99 (from $120)
Grab two Amazon Echo Show 5 smart displays and use the code SHOW52PK to get them for $89.99 total. They would cost you $120 without that deal, so you're basically getting a second device for 50% off. Whether you want two smart video displays in your home or just want to give one away as a gift for someone you missed at Christmas, this is a great deal that saves you a good chunk of money.
Amazon Echo Show 5 double trouble
This is a compact 5.5-inch smart display with Alexa built in. Manage your calendar, make to-do lists, get weather updates, or follow along with recipes on the screen. Use your voice to control your devices and view feeds on the display.
Ring Video Doorbell Wired with Echo Show 5
$64.99 $139.98 Save $75
The Ring Video Doorbell is bundled with Amazon's Echo Show 5 at over 50% off exclusively for Prime Day. You'll be able to see who's at your door using the Ring app on a myriad of devices, including the Echo Show 5.
Fire TV Stick 4K with 'The Disney Bundle'
Limited Time Only
Exclusively during Prime Day, Amazon is offering Prime members three free months of 'The Disney Bundle' with the purchase of a new Fire TV Stick or Fire Tablet. The Disney Bundle gives subscribers access to Disney+, Hulu, and ESPN+.
Amazon Prime Video Channels
Limited Time Only
Amazon Prime Video lets you add other streaming services as 'channels' to your Prime subscription, and right now select options are down to just $1 per month ahead of Prime Day!
Amazon Echo Devices
Prices Vary
Featuring the Echo, Echo Dot, Echo Show 5, Echo Auto, Echo Frames, and more, this sale lets you snap up some Amazon hardware without breaking the bank. These are some of the best prices ever, tough they are just for Prime members.
Amazon Kids+ Family Plan
$0.99 $29.99 Save $29
One of the best deals to come to Amazon Kids+ is now available exclusively for Prime members! Your family can score three months of access for only $1 by signing up before Prime Day begins on June 21.
Oria 126-in-1 Precision Screwdriver Set - $19.49 (from $30)
Oria's screwdriver set, which is discounted to $19.49 using the code WXYXPTXCG, comes with 112 different kinds of screwdriver bits made of chrome-vanadium steel, all of which have been carefully selected to help fix popular devices, eyeglasses, and more. The kit also includes accessories such as a screwdriver handle, an opening tool, tweezers, and a SIM card tool. It even comes with a flexible extension shaft to help you work in tight, narrow spaces. Oria includes a nylon bag with this kit's purchase to keep everything carefully organized while it's stored away.
This portable screwdriver set comes with over 110 different kinds of screwdriver bits so you can always be ready to work on phones, game consoles, computers, or even eyeglasses. Use the following code to save $11 at Amazon.
Oria 60-in-1 Precision Screwdriver magnetic driver kit
$11.99 $20.00 Save $8
Includes 56 precision specialty bits, one magnetized driver handle, a flexible extension, and a driver adapter. Bits made of CRV steel, which means they're hard, durable, and high performance. Repair screws in deep positions and narrow spots.
Oria 60-in-1 Precision Screwdriver Set
$11.19 $15.99 Save $5
This precision screwdriver set comes with 56 varied bits that were carefully selected to help repair popular electronics, eyeglasses, and more. You'll just need to enter the following code during checkout to snag this low price.
$12.41 $17.99 Save $6
This toolkit is great for completing repairs on your electronics as well as doing tasks around the house, so don't miss out on this deal offering 20% off its average price using the coupon code below.
ORIA 25-in-1 Long Screwdriver Kit
$10.87 $16.99 Save $6
From tablets and phones to eyeglasses, cameras, and more, this simple screwdriver kit can help you fix your things rather than replace them or spend all your money at a repair shop. Just make sure to enter the code below to snag the best price on it.
This precision screwdriver set comes with 56 varied bits that were carefully selected to help repair popular electronics, eyeglasses, and more. You'll just need to enter the code below to snag this low price.
Samsung 50-inch 4K Smart TV - $296.99 (from $380)
Not only is this TV on sale right now, but you can also get a free Google Nest Mini smart speaker with the purchase. That's another $50 in savings. Samsung's 50-inch Ultra HD Smart LED TV features an effective refresh rate of 120Hz, two HDMI ports, a USB port, and Dolby Digital Plus audio. It also supports HDR10, HDR10+, and HLG HDR formats and is equipped with Motion Rate 120. The best feature of all, however, is its built-in Wi-Fi that allows you to download apps straight to the TV. From there, you'll be able to access and stream services like Netflix, Hulu, Amazon Prime Video, YouTube, and other top channels. It's even able to access new services like Disney+.
Samsung 50-inch 4K UHD Smart LED TV (NU6900 Series)
This 4K UHD HDR Smart TV offers integrated access to Netflix, Amazon Prime Video, Hulu, and tons of other popular streaming services. Plus, Best Buy is including a free Google Nest Mini with its purchase automatically!
Eufy Security 2K video doorbell - $105.99 (from $160)
Thanks to a limited-time sale at Amazon, Eufy's 2K Video Doorbell is now down to just $105.99 when you clip its on-page coupon and use promo code WRECUTDB2 during checkout. That saves you over $50 off its usual cost of $160.
Eufy's 2K video doorbell has 2560 x 1920 resolution with HDR and distortion correction, which ensures quality video recordings. With two-way audio, you can hear and speak directly to anyone who approaches your door. The camera uses advanced AI technology and algorithms to detect body shapes and face patterns. The system is designed to be weather-resistant too, so you don't have to worry about it being outdoors and exposed to the elements.
Eufy Security Wi-Fi 2K video doorbell
Eufy's 2K Video Doorbell lets you speak to anyone who approaches your front door using an app on your phone. You'll be able to see them too. Clip the on-page coupon and use the following code during checkout to save over $50 instantly.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
Kindle Unlimted 3-month Membership - $0.99 (Save $29)
Buying book after book after book can get pretty expensive very quickly, which is why Kindle Unlimited makes for the perfect alternative. Becoming a member unlocks access to Amazon's vast selection of digital books and more to read when you please, and they're all accessible via the free Kindle app which you'll be able to open and use practically anywhere you go. Now you can take all your favorite books with you without weighing down your luggage, and the best part is you can join today with a three-month membership for only $0.99.
Amazon Kindle Unlimited 3-Month Membership
Score three months of access to Kindle's digital eBook library for only $1 with this exclusive deal at Amazon. You'll be able to read the eBooks using the free Kindle app on a myriad of devices; no e-reader required.
Answer the call
Mint Mobile is offering up to 40% off its service plans for three months when you join now! You can score any data plan for only $15 monthly for three months, though you'll need to pay the full three-month cost in advance.
Extra security
Security and privacy are important, but that doesn't mean you can't make a saving! This limited-time holiday offer at PureVPN drops the monthly cost to just $1.19 with code THRIFTER10. It works great on iOS, Android, macOS, Windows, and more.
Free radio
This service launched earlier this year costs only $8 a month anyway, but you can get three months for free. The Essential bundle includes 300 channels of music, comedy, talk radio, and more. It's only for online streaming not using your car's satellite radio. Remember it will auto renew.
