The GoGroove FlexSmart X2 Bluetooth car FM transmitter and USB charger is down to $15.99 through Woot. The same transmitter goes for around $30 at Walmart and other retailers.
Listen
The GoGroove is easy to set up and use, works with all Bluetooth devices, and can even work with two devices at once. This deal is almost half off what it sells for at other retailers.
$15.99 $30.00 $14 off
Use your Amazon Prime account to avoid Woot's mandatory shipping fee.
Use the GoGroove to listen to your smartphone's audio through your car speakers. The on-board controls include easy access to the volume, Bluetooth pairing, and buttons for receiving calls. It can pair two Bluetooth devices simultaneously, which is great if you have a couple of car DJs on the road with you. The built-in mic has enhanced voice detection, and the USB charging port lets you keep your device powered up while you're streaming music.
