Keep your gear powered up with Aukey's discounted USB-C PD wall charger for $11
The Aukey USB-C wall charger with 18W Power Delivery is down to $10.99 in white with code 9VO4Q3XT on Amazon. That price is $11 off what this charger normally sells for and matches the last deal we saw on it. You can also score the black version of this charger for the same price using code 95SGCK4R.
On the other hand, if you could use a wall adapter that also has a Quick Charge 3.0 USB-A port, you could grab Aukey's 18W USB-C Wall Charger for $12.99 using promo code YA62M8E2.
If you have a phone or tablet that supports Power Delivery and USB-C, you'll get a lot out of this wall charger. It can charge up to 18W and transfers juice a lot faster than a regular charger. The foldable plug and compact design means you can shove it in your bag and take it with you wherever you go. Plus, it has all the usual safeguards to prevent things like overheating or overcharging. Aukey gives the charger a two-year warranty. Users give it 4.2 stars based on over 120 reviews.
