Best Charging Stations for Arlo Pro and Arlo Pro 2 in 2022
If you have the Arlo Pro or Arlo Pro 2 security camera from Netgear, then you have a security camera with rechargeable batteries or a solar panel. The problem is that, without a charging station, you can only charge the batteries by plugging in in your camera. If you need a spot to charge your cam's batteries, then check out one of these charging stations made specifically for the Pro and Pro 2.
Netgear Arlo Pro charging station
Who better to buy from than the manufacturer itself? The Arlo Pro charging station features two battery docks, which is perfect if you have more than one camera around the house, and it doesn't matter if it's the Pro, Pro 2, or Go.
At roughly $60, this is the priciest option on the list, but it's straight from Netgear, so you know it's guaranteed to work. Netgear also promises that this will charge four times faster than competitors.
Wasserstein charging station
Rather than Netgear's side-loading charging station, Wasserstein's lets you load in two batteries from the top. This station works with Arlo Pro, Pro 2, and Go batteries and the LED indicator will let you know when everything's ready.
If you use the discount code ARLODEAL when you check out, you'll receive deals when you buy multiple Arlo accessories from Wasserstein. For around $35, this is your least expensive option and a solid one if you're just looking for a decent third-party charging station.
See at Amazon
Holaca
Wanna Holaca love, wanna Holaca love, wanna Holaca love. Sing it. It's fun. Holaca's charging station is as basic as it gets: it's a short station on which you place either your Arlo Pro or Pro 2 battery, and it's without those boxy slots sported by the other two options on the list. You can charge up to two batteries at the same time, and you'll get the USB-C cable and wall adapter in the box.
Holaca provides a 12-month warranty, which'll net you a replacement for a faulty station or a full refund if that's your fancy. This one's about $37.
See at Amazon
And you?
Pickings are pretty slim for Arlo Pro charging stations, so what do you use? Let us know in the comments below!
Mick Symons
Mick is a staff writer who's as frugal as they come, so he always does extensive research (much to the exhaustion of his wife) before making a purchase. If it's not worth the price, Mick ain't buying.
