The Choetech car air vent wireless charger mount is down to $17.99 at Amazon when you clip the on-page coupon for $2 off and enter code EWFGHUN6 during checkout. The charger sells for $29 without the coupons, a price it has mostly remained at so far this year. Late last year it was selling for $33.
Quick ⚡️
Choetech Fast Wireless Charging Car Mount
Once installed, all you have to do is drop your phone in it for a secure fit and quick charge on the way to work. Be sure to use the on-page coupon and enter EWFGHUN6 at checkout for the full discount.
$17.99 $28.99 $11 off
With coupon: EWFGHUN6
The car mount supports wireless charging for any Qi-enabled device. At a minimum, you'll get a 5W charge. The new iPhone models will get 7.5W fast charging, and Samsung phones like the Galaxy S9 will get 10W. When you drop your phone into the mount, the side brackets will automatically fit your phone and lock it securely in place. The brackets are limited to phones up to 3.4 inches across, including cases (which shouldn't be thicker than 5mm for the wireless charging to work). The wireless charging starts automatically, too, so the whole thing is super convenient for drivers. It installs without any extra tools right on your car's air vents, and it will be held there tightly thanks to an anti-slip L-shaped hook design. The mount comes with an 18-month warranty.
You will need a Quick Charge 3.0 car charger like this one from RavPower plugged into the mount to get the fastest possible wireless charge.
