It doesn't cost too much to add a few more ports to your computer if you can snag a USB hub while it's on sale, like this Aukey 7-in-1 USB-C hub with Power Delivery pass-through. Thanks to the promo code BVGREEMN, you can snag one for only $24.99 on Amazon. Without the discount, this hub goes for $50 and never drops from that price except through unique deals like this. Make sure the product page says it's being sold by "Aukey Direct" and not "Aukey Store." They are confusingly similar but the code will not work on the latter.
Adapt and thrive
This adapter just does so much with one simple USB-C port. And the price is basically 50% off with the coupon code below.
$24.99 $50 $25 Off
With coupon: BVGREEMN
Aukey has only offered this Power Delivery version of its USB-C hub since about October last year, so there hasn't been a lot of time for awesome discounts like this. The hub includes three USB 3.1 Type A ports, SD and microSD card slots, an HDMI port, and a 100W USB-C Power Delivery port. The HDMI port is capable of outputs up to 4K to a connected display. All the USB-A ports and SD slots support data transfer rates up to 5 Gbps. The Power Delivery port is powerful enough to charge your MacBook and other USB-C devices using the original power adapters thanks to 100W pass-through.
Save big with VPN deals from ExpressVPN, PureVPN, Surfshark & more
Aukey backs it up with a two-year warranty, and users give it 4.3 stars out of 5 based on 137 reviews.
Get Connected
Aukey 6-in-1 USB-C hub
This USB-C hub doesn't feature a Power Delivery pass-through port, but otherwise, it's not missing anything compared to the model above. If you're looking for the most affordable option, this is your best bet when you use the code below during checkout.
$19.99 $40 $20 Off
You can also get the version without Power Delivery on sale right now for $19.99 using the same code during checkout.
