Despite fast charging being available in iOS devices since the iPhone 8, it isn't widely used because it previously required Apple's own USB-C to Lightning cable to achieve. Now that third-parties can make these cables, we're seeing a bunch of affordable options hit the market. One such option is the Choetech USB-C to Lightning cable. It regularly sells for $17, which is already less than the first-party option, but drops to only $10.74 when you clip the on-page coupon for $2 off and enter code 2PXUVM32 during checkout.
Choetech USB-C to Lightning Cable
Clip the on-page coupon and enter the below code to get this cable at $6 off.
$10.74 $16.99 $6 off
With coupon: 2PXUVM32
Choetech's cable is 6.6 feet in length — twice as long as Apple's cable — and is MFi-certified meaning it has passed Apple's tests for safety and functionality. It can be used to sync data to your iPhone or iPad as well as charging. If used with a compatible USB-C wall charger, you can make the most of fast charging which can take your iPhone from 0% to 50% in just 30 minutes. The Choetech cable should last longer than Apple's version too with a 10,000 bend lifespan and reinforced connectors.
Over 250 amazon reviewers give these cables a stellar average rating of 4.5 out of 5 stars.
