If you've been looking for an MFi-certified battery case for your iPhone X, options have been slim to none until just recently. Moment's Battery Photo Case had a successful Kickstarter campaign and made its debut for purchase at $99.99 this past September as the first. Mophie's Juice Pack Air battery case just became the second.
Specifically designed for the iPhone X, the Juice Pack Air is said to extend the battery life of your phone up to 30 hours thanks to its integrated 1,720mAh battery. Though battery cases tend to be thicker than standard options, this slim case is compatible with QI wireless chargers which will allow you to charge both the phone and the case together.
Raised corners help reduce the risk of scratches and cracking your screen, while internal rubberized support pads protect your iPhone from inside the case when it gets dropped. The back of the case is equipped with LED status indicators which can show your battery level or charge status.
Mophie's Juice Pack Air is now available on its website for $99.95 in black and blue, though blue is sold out at the time of this article's posting. The black and blue models of the case are also available at Amazon; though both are temporarily out of stock at this time, you can place an order and have it shipped once more stock arrives.
iOS gaming recap: Is that Pokémon Go meets... basketball?
Ever wanted to play basketball but as Pokémon Go? What about hopping into some more dino action now that the Jurassic World series has seemingly wrapped up? Check out this week in iOS gaming.
Huge Apple TV promotion now live ahead of major upgrade
You can now get a $50 gift card when you buy either of Apple's TV models. The company is likely cleaning house ahead of a rumored big upgrade.
New M2 13-inch MacBook Pro teardown shows it's just the old one in disguise
Apple's new M2 13-inch MacBook Pro is now on sale and people are doing what they tend to do with new things — they're taking the machine apart. The latest to take a screwdriver to Apple's new notebook is iFixit, and the result is further confirmation that this is essentially the M1 model but with some small tweaks and a new CPU.
Deck your dorm with the coolest stuff
Dorm rooms can be plain, so you're going to want to deck it out with as much cool stuff as you possibly can - here are our picks for the essentials!
