Apple only just opened up the certification process for USB-C to Lightning cables, and one of our favorite accessory makers already has some on the market. Right now you can pick up Anker's USB-C to Lightning Powerline+ II cable for just $17.59 in your choice of black or red when you use coupon code ANKER652 during checkout. This is one of the first third-party cables to be released that is certified from Apple, which means it passes all the safety tests required to properly charge your device. Normally, it sells for $22 and this is the first time we've seen it fall below that price.
Fast charge
Anker Powerline+ II USB-C to Lightning cable
Take advantage of the iPhone's fast charging capabilities with a cable that supports it and won't wear out from regular usage. Anker's rugged Powerline+ USB-C to Lightning cable is $4 when you use the below coupon at checkout.
$17.59 $21.99 $4 off
With coupon: ANKER652
The Powerline+ cable features a braided nylon design for added durability. It's designed to withstand 30,000 bends without any issue, and Anker is so sure of its long-lasting performance that the company backs it with a hassle-free lifetime warranty. The cable can support USB-C Power Delivery up to 87W with the right power adapter, allowing you to fast-charge your iPhone. If you've upgraded to a newer MacBook and don't have a full-size USB port anymore, these cables are an absolute necessity. If you don't need the increased durability of nylon, the regular Powerline USB-C to Lightning cable is currently down to $16 right now with no promo code needed. It supports the exact same speeds and is also MFi-certified.
Odds are you'll want to grab a couple of these at this price so you have one for the house, one for the car, one for the office, and even one to keep in your travel bag.
More Cyber Monday deals:
