Apple only recently opened up the certification process for USB-C to Lightning cables, and accessory makers are already getting their own versions onto the market — and for much less than Apple's cables cost. Right now you can pick up UGREEN's new USB-C to Lightning cable for just $9.09 when you use coupon code UGREEN35 during checkout. This is one of the first third-party cables to be released that is certified from Apple, which means it passes all the safety tests required to properly charge your device. Normally, it sells for $14, which is already pretty amazing, and today's price drop is an all-time low.
Speedy
UGREEN USB-C to Lightning cable
At this price, you're going to want to get a couple of these cables and start fast charging all of your iOS devices.
$9.09 $13.99 $5 off
With coupon: UGREEN35
Using it, and a compatible USB-C adapter, you'll be able to charge up your devices super quickly. It's not widely publicized, but fast charging has been present in the iPhone since the iPhone 8 and iPhone X were released, but it can only be done using a USB-C to Lighting cable and Apple was previously the only provider of those. Using UGREEN's cable with a USB-C adapter will allow you to charge your iPhone from 0% to 50% in 30 mins. Fast charging also works on Apple's newest iPad models.
The cable is 3-foot in length and also works for high-speed data transfers up to 480Mbps. Plus, if you've upgraded to a newer MacBook and don't have a full-size USB port anymore, these cables are an absolute necessity. I actually own and use this cable and it works exactly as advertized so it makes no sense at all to spend three times as much on the official Apple version. Odds are you'll want to grab a couple of these at this price so you have one for the house, one for the car, one for the office, and even one to keep in your travel bag.
