Best Accessories for 11-inch iPad Pro iMore 2022
Looking for the perfect accessory for your 11-inch iPad Pro? Then look no further! From Apple Pencils to keyboards, and everything in between, this list has you covered. Here are the best accessories you can buy for 11-inch iPad Pro!
- Your music, your way: Beats Solo Pro Wireless Noise Cancelling Headphones
- Go (mostly) wireless: Beats Powerbeats 4
- The Apple Pencil: Apple Pencil (2nd Generation)
- Noise-cancelling earbuds: Pioneer Rayz Pro Active Noise Cancelling Earphones
- Carry your iPad Pro in style: Waterfield iPad Pro Sleevecase
- Smart and safe: Smart Folio
- Type it out in style: Logitech Keys-To-Go Wireless Bluetooth Keyboard
- Versatile and functional: Compass Pro
- The perfect companion: Smart Keyboard Folio
- iPad trackpad anyone?: Magic Keyboard
- So much power: ELECJET PowerPie 20000mAh Power Bank
- Truly magical: Apple AirPods Pro
Staff favoriteFeaturing Active Noise Cancelling (ANC) and Transparency mode, the Beats Solo Pro offers a fully immersive sound experience. Available in multiple colors, the headphones can deliver up to 22 hours of battery life between charges.
Apple is referring to its Powerbeats3 replacement as Powerbeats, and these new high-performance earphones are more powerful than they've ever been. The earphones are powered by Apple's H1 chip, which will make connecting to the iPad Pro super seamless.
If you're looking for a perfect partner for your new 11-inch iPad Pro, then you might want to take a peek at the Apple Pencil (2nd Generation). The Apple Pencil has an intuitive touch surface that supports double-tapping and a magnetic, flat edge that attaches for automatic charging and pairing.
Staff favoriteWith adaptive noise canceling, the Rayz adjusts the sound based on the environment around you. The Lightning-powered device comes with a USB-C adapter, so you can also use it with your iPhone.
Want a case that'll keep your iPad Pro protected while still providing ample space for other accessories? Then peep this Waterfield iPad Pro Sleevecase. The Waterfield iPad Pro Sleevecase is a thin, soft leather case with a handle that'll keep your iPad safe from dust, dirt, and the perils of the outside world. While it's isn't particularly rugged, it's simple design makes carrying your iPad a breeze.
Sometimes the only thing you need for your iPad is a folio, so check out the Apple's Smart Folio. This folio offers protection for both the front and back of your iPad and comes in Cactus, Surf Blue, Pink Sand, Black, and White color options. Apple's Smart Folio has been redesigned to perfectly fit the 2020 iPad Pro's new camera layout, but if you don't mind the extra space, you can also use it on your 1st Gen 2018 model.
The Logitech Keys-To-Go Wireless Bluetooth Keyboard is an ultra-thin, lightweight, and super adorable keyboard that'll have you typing up a storm on your iPad Pro. This little accessory promises quiet typing, a smooth, soft keyboard feel, and a 3-month battery life, so you won't have to worry about charging it at the end of every day.
Looking for an iPad Pro stand that'll work both vertically and horizontally while still looking sharp and minimalistic? Then you have to check out the Compass Pro. This affordable stand has soft silicone padding on its feet, so your iPad won't slide off the table. The Compass Pro can be folded flat, so you can pop it in a case and take it on the go.
The official folio for the iPad Pro isn't for everyone, but it's the official one nonetheless. Featuring a full-size keyboard, this product requires zero charging or pairing; just attach the keyboard and start typing! The Keyboard Smart Folio from Apple was created with the new iPad Pro camera setup in mind, but will definitely work with the older model, if you're willing to overlook the extra space around your single camera.
If you love the current Keyboard Folio, but you've always wanted a more laptop feel then look no further. Apple's Magic Keyboard features a new trackpad that'll take your productivity to the new level. There's also a USB‑C port for passthrough charging and a floating design, which will make it easy to adjust viewing and typing angles. The Magic Keyboard will be available in May and will technically work with both iPad Pro models, but will leave some space around the 1st Gen camera since it was designed to accommodate the bigger bump of the 2nd Gen.
Featuring USB-C, just like the 11-inch iPad Pro, the ELECJET PowerPie offers 30W PD fast charging that takes just 2 1/2 hours to complete. Up to 37 percent of the charge is completed in less than 30 minutes.
The hottest Apple accessory of the year works really well with the 11-inch iPad Pro. Get one and enjoy your favorite music with ease.
Tough protection: Otterbox Symmetry Series 360
OtterBox is known for combining tough protection with stylish designs, and its Symmetry Series 360 iPad Pro case is proof of that. The new folio case is ultra slim and versatile, allowing you to adjust your iPad Pro in multiple ways for the most comfortable typing positions and hands-free viewing. Much like the official Apple cases mentioned, the Symmetry Series 360 will also work on both iPad Pro models but will offer a more snug fit around the larger camera bump of the 2020 model.
All the ports: HyperDrive 6-in-1 USB-C Hub
If you're looking to replace your laptop with your iPad Pro, you're going to need all the ports you can get, and HyperDrive has got you covered with its 6-in-1 USB-C hub. The hub displays just how powerful it is by turning the iPad Pro's single USB-C port into 6 ports, including a 3.5mm Audio Jack, USB-A, SD, Micro SD, and HDMI ports. The hub will work on the iPad Pro 2020 and iPad Pro 2018.
Lots to see
Whether you're looking for a fresh set of headphones or the brand new Apple Pencil, there are plenty of accessories to pick from that will mesh perfectly with your new iPad Pro. Because I'm a believer that work performance is always improved with music, I suggest getting your hands on the Beats Solo Pro. If you like music, but rather not carry around a full-size pair of headphones, consider the AirPods Pro.
For something much more practical for your tablet, you should consider the ELECJET PowerPie or Smart Keyboard Folio Both are powerhouses that will get the job done.
Keep the 11-inch iPad Pro screen pristine with these screen protectors
The 11-inch iPad Pro is even better when paired with a screen protector. Here are our favorites, no matter which year your iPad Pro is from.
Keep your iPhone 13 looking cute with one of these adorable cases
Who says your iPhone case has to be boring? Express your style and protect your iPhone 13 with one of these adorable cases.
Buy the cutest case for the cutest iPhone, the 13 mini!
The iPhone 13 mini is a pretty sweet phone. How about an adorable little case to match?
