Best smart plugs for HomeKit and the Home app in 2026
Want to switch off your plugged-in gadgets without reaching for the wall switch? How about checking they're off when you're out of the house? The best smart plugs for HomeKit are sure to make things a little easier for you, as they can do all of that and more.
Being the best way to make non-smart gadgets feel a bit smarter, instead of buying a new device to be able to control it from your iPhone 15, you can simply control the plug and fit it into any group of shortcuts you like.
Latest Videos From
With Siri at the ready and enough smart plugs set up, you could theoretically control most of your house with just a phone at your side. However, there are tons of great options out there, from budget choices, to super small plugs.
Here are the best smart plugs for HomeKit out there right now.
Quick List
Q&A
Do you need a smart plug?
Not everyone needs a smart plug. The best smart plugs for HomeKit bring you a cheap and simple way to create smart home devices from “dumb” ones.
A smart plug is a good idea if you want to dip your toe into the smart home space but don’t want to spend a small fortune on new devices just yet. It’s also a good idea to buy a smart plug if you have a lot of regular, “unsmart” appliances that you use often, like say a coffee machine or a lamp. That way you can use the smart plug to set up HomeKit automations or control them with your voice thanks to Siri.
However, some people might want to skip this step and revamp their homes with new smart tech, in which case we’d recommend you look at our best HomeKit devices guide for tips. Or read our Apple HomePod 2 review if it’s a smart speaker you’re looking for.
What should you look for in a smart plug?
If you're looking for the best smart plug, the first thing you need to consider is compatibility. All of the suggestions in this guide work well with HomeKit, but it's worth making sure all of your favorite apps are supported.
We also recommend that you consider where your new smart plug is going to go. Will you need to choose a sleek, nice-looking device or can it hide behind a table or settee?
Our top pick for the best smart plug for HomeKit goes to the Eve Energy, which you'll find in the top spot in the guide above.
We love this smart plug for its slim form factor, energy monitoring capabilities, and the fact that it doesn't need a hub since it utilizes Thread and Bluetooth connectivity. These features make it one of the best for those new to home automation.
If you're looking for a smart plug for the great outdoors, another favorite of ours is the meross Outdoor Smart Plug. This weather-resistant smart plug features three independent outlets so you can control all of your outdoor decorations and lights. Plus, with support for other platforms like Alexa and Google, you are not locked into just HomeKit.
What does a smart plug do?
It's very simple — it plugs into an outlet, and then you plug the device you want to make smarter into the socket on the other side. It will then power on and off, deciding when the device that's plugged in gets power according to how you control it with the Home App.
The idea is to make older devices smart, giving old lights, coffee machines, or even radios a new lease on life. It is way cheaper than investing in something brand new, and while perhaps less flexible than something built from the ground up with HomeKit compatability, it is a great way of making your every day items easier to use.
With contributions from
