Deebot 900 Deebot OZMO 930 compare
Best answer: The main difference between these two ECOVACS smart vacuum robots is that the 930 model also mops.
Deebot vs. Deebot OZMO
Regardless of the specific model number, ECOVAC Deebot robots marked as "OZMO" also work as a mop. Otherwise, they only perform as a dry vacuum. In this case, the Deebot OZMO 930 is a vacuum/mop, while the Deebot 900 is exclusively a smart vacuum.
The OZMO 930 is the first Deebot to include Adaptive Floor Sensing technology. With this tool, the robot's sensors can detect when it's on a carpet and adjust the suction power appropriately. During the moping process, the machine can avoid carpets using the same technology.
The vacuum/mop also offers more run time, 110 minutes between charges versus 90 minutes for the vacuum only model. Also, the 900 is white, while the Deebot OZMO 930 is available black.
About the mop
The mop on the Deebot OZMO 930 uses an electronically-controlled water pump that uses sensors to monitor water flow. Controls ensure a consistent cleaning result by stopping the water flow, when necessary.
What they have in common
Beyond this, these two smart vacuum robots are essentially the same. Both, for example, offer Smart Navi technology, a laser-based navigation tool that scans and maps cleaning areas. In doing so, the machines adapt to your home, enabling efficient cleaning. Smart Navi also allows you to draw virtual boundaries or pinpoint specific areas to clean or avoid using the free ECOVACS app.
Both machines also include two interchangeable suction inlets. One of those offers a tangle-free experience for those times when the robot might run into cords and pieces of hair. Each robot also includes Amazon Alexa and Google Assistant integration, the ability to schedule cleaning times, automatic recharging, and more.
Buy one
ECOVACS Deebot OZMO 930
It's all here
The ECOVACS Deebot OZMO 930 is ideally suited for anyone looking for an all-in-one vacuum and moping solution.
An alternative
ECOVACS Deebot 900
Worth considering for less money
The ECOVACS Deebot 900 doesn't offer mopping capabilities. Despite this, it still offers most of the features of the Deebot OZMO 930, but for less.
