There are plenty of smart home products designed to only work inside your home, but the Eve Aqua smart water controller is one of the few which is built for the outdoors, allowing you to control the water faucet you attach it to using your smartphone. While it's regularly priced just under $100, today you can pick one up for only $74.50 when you clip the coupon on its product page at Amazon. That brings it to the lowest price we've ever seen it reach there.
Smart Buy
The Eve Aqua lets you control your outdoor faucet using Siri, a free app on your phone, or its onboard buttons. Simply clip the coupon on its product page to score one of its best prices ever.
$74.50 $99.95 $25 Off
With Eve's water controller you'll be able to access your sprinkler system through the free app, Siri using Apple HomeKit, or manually with the onboard buttons. It's also capable of adapting and running automatically. The controller shuts itself off so you don't risk flooding your yard or waste any time. You can also set schedules yourself, check consumption, and track your usage. Meanwhile, the included Child Lock helps prevents any unwanted attention.
This is a battery-powered device that comes with two AA batteries, but you might want to keep more around just in case. It's also Bluetooth only, so you'll want something within Bluetooth range of it wherever you use it.
