Best portable charger for Nintendo Switch Lite 2023
Nintendo Switch Lite Yellow
Nintendo Switch Lite Yellow (Image credit: Nintendo)
You can never have enough battery life for any portable device, and the Nintendo Switch Lite is no exception. The console has a battery capacity of 3,570 mAh, which means it should last approximately three to seven hours, depending on what games you are playing. For any journey longer than a few hours, you'll definitely need a portable battery pack as one of the key Nintendo Switch accessories to pair with it. Here are some of the best battery backups for the Nintendo Switch Lite that money can buy.
Don't let the fun stop on the Switch Lite!
All these battery packs are a good choice, though it depends entirely on what you plan on using them for. In terms of ease of portability, the Anker PowerCore 10000 is our favorite. Being able to charge the Nintendo Switch Lite almost three times means that you can keep playing for a long time without being burdened by a heavy battery pack.
Need to charge more than one device at the same time and recharge the battery pack swiftly? Look no further than the Anker PowerCore III Elite 25600. Are you thinking of going hiking or on a camping trip with your new Nintendo Switch Lite? If so, then make sure you check out the solar-powered Kepswin Solar Charger 20000mAh, which is also waterproof, dustproof, and comes with a built-in flashlight as well.
Battery packs aren't the only accessory you need for the Switch or Switch Lite. If you're picking up either of Nintendo's portable consoles, consider some key accessories to go with it that will make your experience with the console easier and more enjoyable.
Alex Huebner
Contributor
Alex has been working with iMore as a Freelance Gaming Writer for three years. You can also find a few articles of hers on Android Central and Windows Central. She regularly covers Nintendo Switch games and accessories as well as iOS game apps. In addition to the Nintendo Switch, you may also find her playing on the PlayStation and PC. When she doesn’t have a controller in hand she likes to spend her time with her husband, son, and dogs, exploring new places, or hiding away with a book (or comic book). A few of her favorite games include the Zelda franchise, Little Nightmares, and Animal Crossing.
