Best Nintendo Switch OLED cases that fit in the dock iMore 2022
The Nintendo Switch OLED provides a clean revision of Nintendo's hybrid gaming console. The larger OLED screen means there's a new dock, which in turn means that you'll need new cases if you want to keep your Nintendo Switch protected while it's in the dock. We've rounded up a few options for you to choose from.
- Well protected: Mumba Dockable Case - Nintendo Switch OLED
- Cheap option: HEYSTOP Dockable Switch OLED Case
- Clean screen: AKNES Nintendo Switch OLED Case
- Sparkly protection: DLseego Protective Glitter Case
- Totally encased: SUPCASE Nintendo Switch OLED case
- Unique design: Clolow Dockable Case for Nintendo Switch OLED
Staff PickThe Mumba case for the Nintendo Switch OLED is perfectly compatible with the dock. The material is both scratch-resistant and shock absorbent, whether you're safekeeping it in the dock or picking it up and carrying it around. You can even remove the Joy-Cons without taking the case off, so you're good to keep it on as long as you want. Get it in black, purple, white, blue, or red.
With its minimalist design, textured grips, and ability to fit into a Switch OLED dock, this case is a great purchase for anyone looking to save some money. The case is designed in such a way that you can still use the kickstand, plus it comes with thumb grips to give you more traction while playing your games. You can get it in black, white, or pink.
The AKNES Nintendo Switch OLED case is a combination, including a hard shell that'll help protect your Switch from damage. It's also got a glass screen protector, ensuring that the big OLED screen stays safe and won't get dirty or damaged from everyday use, even if you're sliding it in and out of the dock regularly. It comes in black, clear, grey, or white.
Give your Switch OLED a fun glittery theme with this clear protective case. It even covers the kickstand in such a way that you'll still be able to use it at varying angles. Plus, it's so thin that it easily fits into the Switch OLED dock, so you can place it or pull it out of TV mode whenever you'd like.
If you're extremely nervous about your Nintendo Switch OLED being damaged in or out of the dock, consider the SUPCASE Nintendo Switch OLED case. The material is designed to absorb as much wear and tear as theoretically possible while still not cutting off access to the different ports.
Give your Joy-Cons and Switch OLED a matching theme while still making your kickstand usable. Just slide it over your console and Joy-Cons and you're good to go. You can get it in this fun blue dragon theme, a black Zelda Breath of the Wild theme, or a white Sailor Moon theme.
Keep your OLED safe
The larger size of the Nintendo Switch OLED means that while you can still use all your Joy-Con controllers, you'll need new accessories, which extends to the case. No matter what case you pick, you can have peace of mind that your Nintendo Switch is secure while playing it on the go or docked. This will ensure you aren't distracted from playing through the best Nintendo Switch games.
We recommend grabbing the Mumba Dockable Case for Nintendo Switch OLED for the best overall balance. This case provides a great amount of protection while not being too bulky that it's awkward to use. Some Nintendo Switch screens get scratched when taking it in and out of the dock, so a case is a solid way to prevent that.
If you want a carrying case, you'll need to look elsewhere and consider investing in one of the overall best Nintendo Switch OLED cases. For anyone valuing the flexibility afforded by a case that works with the dock, you'll be happy with one of these options.
Get the rarest gift for the Nintendo Switch amiibo collector in your life
Nintendo's amiibo lets you collect all of your favorite characters and gain some in-game benefits for having the figures. Here are some of the most expensive and hard-to-find Nintendo Switch amiibo figures on the market.
Apple Wallet has got some healthy competition with these MagSafe options
Since Apple's MagSafe system came out in 2020, plenty of iPhone accessory manufacturers have churned out new accessories in answer. These are the best MagSafe wallets, both Apple and otherwise.
All the limited and special edition Nintendo Switch consoles you can buy
Don't want your Nintendo Switch to look like everyone else's? These limited edition Switch consoles will stand out in a crowd — and you can buy one today.
