Best Nintendo Switch OLED screen protectors iMore 2022
The new Nintendo Switch OLED has released, bringing with it a larger 7-inch screen than the original Nintendo Switch. As such, it needs a larger screen protector to keep it safe. There are plenty of options out there, but some are definitely better than others. We've rounded up the best options to choose from. To keep your new device safe, don't forget to grab one of the best Switch OLED cases as well.
- Installation helper: iVoler Tempered Glass 4 Pack
- Very popular: amFilm Tempered Glass Screen Protector for Nintendo Switch OLED
- Ultra defense: Zagg InvisibleShield Glass+ Defense Nintendo Switch OLED screen protector
- Crystal clear: Feriliniso Nintendo Switch OLED screen protector
- Perfect alignment: amFilm OneTouch Glass Screen Protector Nintendo Switch OLED
- Trusted brand: JETech Screen Protector for Nintendo Switch OLED 2-pack
Staff pickThis pack comes with four glass screen protectors and a helpful alignment frame to help you put them on correctly. If you happen to mess up, there are plenty of extras to use.
The amFilm Nintendo Switch screen protector is one of the thicker glass screen protectors on this list at around 0.3mm, but it should stand up to the toughest of scratches. Plus, it ships with two protectors in the box, so you have a backup just in case of emergencies!
Want to give your Switch OLED the very best protection? This one is made of aluminosilicate glass making it 95% stronger than common competitors. Plus, the oil-resistant finish helps it look cleaner for longer.
These durable glass coverings will help reduce fingerprints and offer a scratch resistanct surface. The pack comes with three so you can share with someone or have extras to fall back on.
Have trouble getting screen protectors to fit just right? This one comes with an auto alignment kit to help you get the glass protection perfectly in place.
This tempered glass protector has a 9H rating making it a very durable choice. Since it comes with two, there's an extra one in case you mess up or in case you need to replace the first one you install.
Protect that screen
Keeping your brand new Nintendo Switch OLED safe from scratches and damages is very important. After all, it's a rather expensive device and you will probably be taking it everywhere with you. Plus, the Switch OLED has a very nice screen, so you're going to want to keep it lookin' new, right?
While these are all great choices, I highly recommend grabbing the iVolar Nintendo Switch OLED screen protector pack as they are all made of tempered glass — plus, there's an alignment frame to help you put them in position more easily.
Apple Wallet has got some healthy competition with these MagSafe options
Since Apple's MagSafe system came out in 2020, plenty of iPhone accessory manufacturers have churned out new accessories in answer. These are the best MagSafe wallets, both Apple and otherwise.
All the limited and special edition Nintendo Switch consoles you can buy
Don't want your Nintendo Switch to look like everyone else's? These limited edition Switch consoles will stand out in a crowd — and you can buy one today.
Get a grip on your iPhone with these phone grips
No matter which model iPhone you have, you'll get a better grip on it with one of these.
