Best Replacement Charging Cables for Nintendo Switch Lite iMore 2021
Having the portability of the Nintendo Switch Lite makes it easy to love, and having one of these best Switch Lite replacement chargers makes it even easier. Since I do take it everywhere, there is the potential for me to misplace or damage my charging cable which leaves me without power unless I have one of the best Switch Lite battery backups. If this has happened to you, or you're only looking for an extra power cord to keep in a different room, you'll want to make sure you purchase a replacement that works efficiently and safely with your handheld. Here are the best charging cables for Nintendo Switch Lite.
- Power to you: Switch AC Power Supply
- For the road: PowerA Nintendo Switch Car Charger
- Charge more: YCCTEAM Switch Lite Car Charger
- Twin cables: Likada Charging Cables
- Go the distance: Anker Powerline 10-Foot Cable
Staff PickThis is our favorite replacement Nintendo Switch and Nintendo Switch Lite charger. It works efficiently and has a five-foot-long cord. There are protections against over-heating, over-voltage, and short-circuiting. This will easily fit in a travel bag if you're carrying your Switch Lite with you.
If you're the kind of person that prefers officially licensed gear, then this is the car charger to get. It's made by PowerA and is a great choice. The cable is braided which makes it more sturdy against bending and offers high-speed charging.
This car charger is perfect for road trips. It comes with a removable 6.6-foot USB-A to USB-C cable and has two ports so that you can charge two devices. While a USB-A to USB-C cable isn't the best way to charge your Switch Lite, this will work as a good solution for the occasional road trip where multiple devices will need to be plugged in at once.
You get both a red and a black 6.6-foot-long braided nylon cable in this pack. They are perfect for use with the Switch Lite or original Switch. If you want to have one cable for travel and one for home or have a backup just in case, this two in one pack is a very affordable option.
This cable reaches 10 feet long, so it's more likely to be able to reach a power source while you're playing your Switch Lite. The length makes it perfect for travel. It's also made with aramid fiber reinforcement to increase durability.
It's electric
With how portable the Switch Lite is, it can be easy to misplace your charging cable while you're out and about. Or if you're like me, you pick up one of the best Switch Lite replacement chargers just to have more than one charging cable in your home. I have a dedicated charger that I use on-the-go and one that stays plugged into the wall of my living room. I've researched to find the best chargers for your Switch Lite, whether you need a full-on AC charger or simply need the cables.
The best replacement charger for your Switch Lite is definitely the Switch AC Power Supply. It looks a lot like the official charger and doesn't cost that much. If you happen to have both a Switch Lite and the original Switch, you'll be able to charge either device with this power supply.
If you're looking for something to use on a road trip, I highly recommend getting the YCCTEAM Switch Lite Car Charger as it comes with a detachable 6.6-foot cable and offers two ports so you can charge multiple devices at the same time.
Bring more storage to Switch with these microSD cards
The Nintendo Switch only has 32GB of internal storage. That means anyone who plays a lot of games will need to use a microSD card with it. Here are all of the officially licensed microSD cards for Nintendo Switch.
Take your Nintendo Switch Lite on the go with these great cases
Looking to take your Nintendo Switch Lite with you on a vacation or a business trip? Here are the best cases for the job.
Looking for a new controller for your Switch? Look no further!
If you want a more conventional gaming controller for your Switch and don't want to spend more on the Pro Controller, you do have other options. Here are my favorite third-party controllers for Nintendo Switch.
