Best AirPods Pro wireless chargers 2023
If you have the AirPods Pro, you're able to take advantage of wireless charging, so you don't even need a cable to top off your wireless earbuds with extra juice. And if you have the updated AirPods Pro with MagSafe charging case, you can even utilize MagSafe chargers. But what are the best wireless chargers for AirPods Pro? Here are our favorites, and they all should work even if you have a case, regardless of your budget.
Magical magnets
Apple's MagSafe Charger is designed to work with the iPhone 12 and 13 series. Still, it also works for your AirPods Pro, especially if you have the updated MagSafe charging case. In our review, we loved how the MagSafe Charger snaps into the perfect charging position, as well as its 15W charging speeds, making it one of the fastest wireless chargers.
Affordable AirPods charging
Anker is a trusted brand and one that we recommend over everything else when it comes to affordable charging. This simple, non-MagSafe charging pad provides between 7.5W to 10W of power and will work with AirPods Pro wireless charging cases.
All-in-one
If you have all the Apple things, you can't go wrong with Belkin's all-in-one charger. Belkin's charger outputs at up to 15W and has unique arms for your iPhone and Apple Watch, with AirPods Pro going on the base. During our testing, we really liked how the Belkin BoostCharge Pro 3-in-1 Wireless Charger made topping off our devices seamless, plus it just looks great sitting on a nightstand or desk.
Fast simplicity
This sleek and compact wireless charger from mophie has a maximum output of 15W, so you get fast charging for your AirPods Pro and iPhone. It will look great on any desktop, and it is also the perfect size for traveling.
Boost up
This 7.5-watt charging pad from Belkin features an extra-long six-foot cable with a strap and a 20-watt power supply. In our testing, we found that the Belkin Boostcharge Magnetic Portable Wireless Charger Pad's included strap really makes a difference when it comes to portability — so much so that it has become our go-to charger for travel.
Multipurpose charger
The Anker MagGo 633 is a 4-in-1 MagSafe charger that charges your MagSafe iPhone and AirPods Pro, acts as a stand for your iPhone, and has a detachable MagSafe battery pack. It's a little pricey but in our hands-on review, we found the Anker MagGo 633 to be well worth the cost for everything it does.
Juice it up with the best AirPods Pro wireless chargers
While there are a lot of wireless charging pads out there, not all of them work with the AirPods Pro. But the ones we've picked out here will work just fine even if you have one of the best cases for AirPods Pro. Some of them work with multiple devices too, so if you want convenience, they have you covered.
If you want some recommendations for the best AirPods Pro wireless chargers, we love the Apple MagSafe Charger if you have an iPhone 12 or iPhone 13. While the MagSafe part won't work with AirPods Pro unless you have the new MagSafe charging case, it's the perfect size and shape for your AirPods and can provide 15W charging speeds.
Another fantastic option if you have an iPhone 12 or iPhone 13 and an Apple Watch is the Belkin BoostCharge Pro 3-in-1 Wireless Charger with MagSafe. It's sleek, solid, and provides 15W charging for all devices. We also recommend the Anker MagGo 633 Magnetic Wireless Charger. This one is unique because it isn't just a charger and stand as the MagSafe part is a detachable portable battery pack. Seriously, talk about convenience!
iMore Newsletter
