Best wireless headset for Nintendo Switch OLED 2022
Since the Nintendo Switch OLED is such a portable console, it really helps to have a good set of wireless headphones to make the audio experience more enjoyable. That way, you can jam out to your game music while around others without anyone else hearing it. You'll just need to make sure to connect your Bluetooth headphones to your Switch, and you'll be good to go. Here are the very best Switch OLED wireless headphones you can get.
Listen & chat
The EPOS H3 Hybrid has audio mixing, so it can connect to two devices at once, one via a wired connection and another via Bluetooth. This is perfect for the Switch since you can connect to Discord on your phone to talk to friends and to your Switch for game audio at the same time. It comes in black and grey or white and black.
Cat audio
These adorable kitty ears aren't just fun to look at; they provide excellent audio and a comfortable fit. It has a beamforming microphone to pick up your voice when talking to friends or your stream viewers without having a large protruding piece of plastic in front of your face.
Popular choice
HyperX is a very reliable gaming accessory company, and its Cloud II Wireless is one of the most popular gaming headsets on the market. It lasts up to 30 hours on one charge and is built with memory foam for a soft fit. Just plug the dongle into your Switch dock, and you're good to use it.
Budget buy
This awesome-looking headset is perfect for the gamer on a budget. It still provides wireless audio via a Bluetooth adapter while having a flexible microphone and great sound quality, considering the low cost.
Lights and sounds
Looking for the ultimate experience? You can't go wrong with the Corsair Virtuoso RGB headset. It offers excellent clarity and volume with a luxurious, lightweight design. You can even remove the microphone if you don't want to use it. As always, plug the dongle into your Switch dock, and the headset will be good to go.
Sleek design
These sweet headphones light up with red triangles on the sides and have a soft connecting band for ultra head comfort. Volume is somewhat limited, but that also prevents you from damaging your ears. Just plug the included Bluetooth dongle into your Switch OLED's dock, and you're good to use it in TV mode.
Switch OLED jam
The Nintendo Switch OLED model is system with a bigger screen, but having the right audio gear can really help immerse you even further into your games. However, since many Nintendo Switch games do not support voice chat or even microphones, the best Nintendo Switch headset is the EPOS H3 Hybrid. It can connect to two devices simultaneously, one via a wired connection and the other via a Bluetooth connection. That way, you can use it to wirelessly connect to your phone to talk to friends through voice call, Discord, or the like while still being able to plug into your Switch audio.
If you're on a lower budget, I recommend going with the BINNUNE Wireless Gaming Headset. It's hard to find a wireless headset going this cheap while still offering great audio and comfort for the price range. So, it really is a great option to go with.
Lastly, if you want to go all out and have one of the best headsets on the market, you can't go wrong with the Corsair Virtuoso RGB Wireless. The colors on the microphone change, and it has a beautiful design that's both pleasing to the eye and comfortable to wear. Plus, you can adjust equalizer settings to get the perfect sound to match your preferences.
