Skip to main content
Best Ceiling Fans with Lights in 2022
Hunter Symphony Ceiling Fan in a living room setting
Hunter Symphony Ceiling Fan in a living room setting (Image credit: Hunter)
Sprucing up or cooling down a room in your home might mean adding a ceiling fan to improve airflow and to keep things cool in the summer. A fan doesn't mean you have to choose between a light and a set of blades, however, as there are a ton of excellent options that come with a light built right in. Here are the best ceiling fans with lights.
Cool down, light up
Just because you want to get the air moving in your home doesn't mean that you have to sacrifice your lighting. Ceiling fans with light kits offer the best of both worlds, and some of them are even smart and work with apps or voice assistant. All of the above fans can complement a home that needs airflow and light, but if you're still wondering where to start, we have some suggestions.
The Westinghouse 7876400 (opens in new tab) is a great choice if you don't want to spend more than $100 and don't have a large room to cover, while Minka-Aire's fan (opens in new tab) made from koa wood has a unique design that leans more toward the natural look.
Want a ceiling fan that you can control with your phone or voice? Then Hunter's Symphony (opens in new tab) fan is the one for you. This ceiling fan sports a clean, modern design, and connects to your home network via Wi-Fi for the ultimate in convenience. Tell Siri through HomeKit or Alexa to turn on the lights and cool it down with just a shout, or use automations to have the fan kick on when it gets a little stuffy, you can do it all with this fan.
Christopher spends most of his time writing and dreaming about all things HomeKit. If you wish to join him on his quest to automate everything, you can follow him on Twitter at @itschrisclose.
