Source: LifeStraw
Best Filtered Water Bottles iMore 2021
A filtered water bottle can sift out all of the chemicals and metals that are used to initially clean the h2o in your area. This can make the water taste better, amongst other added benefits. You can also use filtered water bottles to clean unmonitored water sources that you find during outdoor adventures. The LifeStraw Go Water Filter Bottle is the perfect filtered bottle that you can even use at home.
- Best Overall: LifeStraw Go Water Filter Bottle
- Best Value: Refresh2Go 26-Ounce Curve Filtered Water Bottle with Grip
- Best for Backpacking: GRAYL Ultralight Water Purifier Bottle
- Best for Sports: Brita 20-Ounce Sport Water Bottle with Filter
- Best for Camping: WaterBasics Filtered Water Bottle
The 23-ounce LifeStraw Go Water Filter Bottle is a wonderfully sturdy water bottle that can be used to filter your h2o for every-day drinking, or for keeping you hydrated during extreme outdoor adventures in the middle of nowhere. This bottle is BPA-free, so you can store water in it for hours on end without having to worry about dangerous chemicals seeping in.
If you decide to take this handy water bottle along with you on a journey into the Amazon, then rest easy knowing that almost any random water sources you find along the way can be made safe enough to drink after being filtered through the LifeStraw Go Water Filter Bottle. This bottle removes 99.9999% of waterborne bacteria and 99.9% of waterborne protozoan parasites through its two-stage activated carbon filter.
The carbon filter can filter out weird odors and questionable tastes, making drinking water more enjoyable. You can enjoy replenishing your body without having to deal with an unappealing aftertaste. The LifeStraw hollow fiber membrane water filter is award-winning and recognized as a must-have in the industry as it doesn't use chemicals, iodine, or batteries to drain out all of the bad stuff.
While this LifeStraw water bottle features a durable silicone straw, some customers mention that the straw can be stiff and hard to drink out of. It has also been noted that the filter can become faulty if it has not been used for a while. This water bottle works best when used daily. Additional filters are sold separately and are easy to replace.
Pros:
- Filters 99.9999% of waterborne bacteria
- Filters 99.9% of waterborne protozoan parasites
- Award-winning carbon filter
- Easy to find replacements for filter
- BPA-free
Cons:
- Straw can be stiff
- Filter does not work as well if not used for an extended period
Best Overall
A durable water bottle that filters out 99.999% of bacteria
This water bottle is great for adventures and every-day use as it can filter out 99.9999% of waterborne bacteria.
Made from all-natural, coconut-shell carbon, the Refresh2Go 26-Ounce Curve Filtered Water Bottle with Grip is an eco-friendly option to filtered water. This water bottle is BPA-free and has been tested and certified by the Water Quality Association. This bottle is great for every-day use and works excellently at ridding tap water of the taste and odor of chlorine.
Featured in this Refresh2Go water bottle is a built-in filter that can work up to 40 gallons before needing to be replaced. This is equivalent to 300 standard-sized disposable water bottles. If you drink three bottles a day, your filter will last you for around 100 days. Feel free to take this bottle with you while camping or on long adventures as you can rest easy knowing the filter is working hard to deliver clean water. This bottle comes with one filter, but additional replacements can easily be purchased.
This water bottle comes equipped with a carrying loop and grip to make transporting it from place to place a breeze. It also features an ergonomic design that is stylish and easy to hold. The included straw is sturdy, but some customers note that it can be quite stiff at first. Cleaning the Refresh2Go 26-Ounce Curve Filtered Water Bottle with Grip is simple. Throw the bottle and cap into the top rack of the dishwasher.
Pros:
- Made from natural, coconut-shell carbon
- Tested and certified by the Water Quality Association
- One filter filters up to 40 gallons
Cons:
- Straw can be stiff at first
Best Value
BPA-free coconut-shell carbon water bottle
This BPA-free water bottle is made from natural, coconut shell carbon and can filter up to 40 gallons of water with one filter.
If you're someone who loves to travel and embark on outdoor adventures all over the world, then the GRAYL Ultralight Water Purifier Bottle is the perfect choice for you. This water bottle is also ideal for keeping inside emergency preparedness packages as it is easy to use and has a fantastic filtration system.
The filter inside this water bottle works extremely hard to removes 99.9999% of viruses such as Hepatitis A, SARS, and Rotavirus. It also filters out 99.9999% of disease-causing bacteria such as E Coli, Salmonella, and Cholera. Also, it can sift out 99.9999% of protozoan cysts such as Giardia and Cryptosporidium. Stay hydrated with clean and safe water while you backpack across the globe with this water bottle.
If you just want an impressive bottle to clean up your tap water and make it more enjoyable, then this bottle is also an excellent option for you. It filters out small particles of sediment, chemicals such as chlorine and benzene, and heavy metals like lead and arsenic. It leaves your water looking clear and tasting fresh.
Although this bottle works extremely hard at delivering safe drinking water, some customers note that the design of the lid could be improved as it comes loose easily, causing the water to leak.
Pros:
- Filters out 99.9999% of disease-causing bacteria
- Filters out 99.9999% of viruses
- Filters out 99.999% of protozoan cysts
- Great for traveling
Cons:
- Lid comes loose easily
Heavy-duty filtration system in a compact water bottle
This compact water bottle features a heavy-duty filtration system, which makes it excellent for traveling all across the world.
Just as the name suggests, the Brita 20-Ounce Sport Water Bottle with Filter is great for keeping athletes hydrated during games or training sessions. This water bottle features a soft-squeeze, plastic design that is BPA-free and made for quick use. Squeeze as much or as little water out as you need to replenish your body during your intense sweat sessions.
This bottle comes equipped with a small filter inside that works hard to deliver precise and fresh-tasting water. It significantly reduces the taste and odor of chlorine that is often present in tap water, making your drinking experience healthier and more enjoyable.
One filter can last up to 40 gallons of water, which means that you won't have to worry about changing the filter for a while. Cleaning the Brita 20-Ounce Sport Water Bottle with Filter is easy. Simply place the bottle on the top rack of the dishwasher. Some customers note that the filter can be hard to remove when trying to replace it.
Pros:
- Filters out chlorine taste and odor in tap water
- Features soft-squeeze plastic
- Great for athletes
- Filters up to 40 gallons of water with one filter
Cons:
- Filter can be hard to remove
Best for Sports
20-ounce water bottle that's great for athletes
This 20-ounce water bottle is excellent for athletes as it features a soft-squeeze design and can filter up to 40 gallons of water.
If you're looking for a water bottle that can keep you hydrated with clean and safe drinking water during your camping trips, then the WaterBasics Filtered Water Bottle may be perfect for you. This water bottle features a certified filtration system that works for 80 gallons of water. Its GRN Line Bacteria Filter has a flow rate of 800 milliliters per minute, so you get clean water at a rapid pace.
You never have to worry about getting sick from drinking contaminated water with this bottle as the GRN Line Bacteria Filter is an excellent defense against protozoan cysts such as Giardia and Cryptosporidium, which are often present in rivers, streams, and lakes. This is a great feature to have while camping.
This 22-ounce water bottle is equipped with a unique and patented Bite Me valve, which means that you have to apply pressure on the valve to drink the water. Once you let go of the valve, it seals itself up to avoid spills. Some customers note that learning this can be tricky at first.
Pros:
- Features GRN Line Bacteria Filter
- Filters 800 milliliters of water per minute
- Has patented Bite Me valve
- One filter filters up to 80 gallons of water
Cons:
- Can be tricky to get used to Bite Me valve
Best for Camping
Water bottle that filters up to 80 gallons of water
This water bottle is great for camping as it filters out bacteria found in rivers at a rate of 800 milliliters per minute.
Bottom line
Whether you are someone who loves to travel and explore the outdoors, or someone who likes to remain in the comforts of your own tight-knit community, having a filtered water bottle can be beneficial to your health. Not only can water bottles sift out harmful bacteria from back-country water sources such as lakes, streams, and rivers, but they can also clear the odor and taste of chlorine from your tap water.
That's why we recommend the LifeStraw Go Water Filter Bottle. This water bottle is BPA-free and can clean up to 99.9999% of waterborne bacteria. Filter replacements are easy to find, and it features a stylish design, making this an excellent choice for both adventure seekers and homebodies.
Camille Sanghera is a freelance writer who loves using the power of words to give individuals and objects a voice. When she is not content writing, you can find her running trails with her dogs or writing novels and ebooks books. You can check out her new blog at www.happycoconut.ca.
Get a better night's sleep with a smart sleeping mask
Need help getting that good night's sleep? Here are the best smart sleeping masks on the market today.
Improve your core strength with these balance boards
Balance boards are useful for increasing your stability, and they can also be used with your standing desk. We've found the best balance boards for your needs.
Need a protein boost? Power your workout with these great protein powders!
Protein is the building block of muscle. Get your protein and fuel your workout with the very best protein powders!
