Charge with Anker's mini 18W USB-C Wall Charger at a new low price of $15
Anker's tiny PowerPort III Nano 18W USB-C wall charger is down to $15.29 at Amazon for the first time ever. That saves you nearly $5 off its full cost and brings the charger down to a new low price with no coupon or code required to score the discount.
Anker PowerPort III Nano 18W USB-C wall charger
This mini USB-C wall charger is just one inch thick and the same size as the adapter that comes standard with an iPhone, but it packs 18W of power inside compared to 5W from the competition.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerPort III is called Nano because it's so tiny. Despite the power behind it, it's roughly the same size as the default wall adapter that comes with an iPhone. It's only one-inch thick and designed to be ultra compact so you can keep it with you wherever you need it. Anker's latest design tech uses custom magnetic components to reduce the size, boost the efficiency, and improve the heat dissipation. I mean, just look at Anker's previous design for an 18W USB-C power adapter, or look at a competitor like RAVPower, and you can see just from the image how much more compact this new version is.
The single USB-C Power Delivery port has 18W of power behind it to provide full-speed charging for phones, tablets, and other mobile devices. Thanks to Anker's new PowerIQ 3.0 tech, the adapter knows what device is being plugged in. It works flawlessly with any USB-C device and provides the most power it can. You'll also receive an 18-month warranty from Anker with its purchase.
You'll need a proper USB-C cable to charge with the PowerPort III nano, so be sure to add one to your order if you don't have one already or would like a dedicated cable to use with this charger. You can find a USB-C to USB-C, USB-C to USB-A or a USB-C to Lightning cable to power your devices with via Amazon.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a Prime member before, you can start a free 30-day trial to score free two-day shipping wtih no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
Alex Smith
