More and more of our devices are starting to adopt USB-C, from our phones to our laptops, so it makes total sense to consolidate our charging gear so we don't have to carry multiple bricks and cables around each day. Anker's 60W PowerPort Atom III USB-C wall charger can be used to juice up all manner of devices and, right now, it's $15 off. The drop to $28.15 from its usual $43 price point marks a return to its lowest ever price.
Get the juice
Anker PowerPort Atom III 60W dual-port USB-C wall adapter
This matches the best price drop we've seen on this charger. With a 60W output via one USB-C and one USB-A port, it can power everything from your phone to your laptop and, thanks to GaN tech, it's smaller than your existing power brick.
$28.15 $42.99 $15 off
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics and can let it in when you need to hear. Battery lasts up to 40 hours with ANC on and 60 hours with it off. First in the series to use USB-C.
Anker Soundcore Liberty Air X true wireless earbuds best buy
These earbuds include expertly-tuned graphene drivers. They have exceptional sound accuracy and great clarity thanks. The aptX codec helps deliver music wirelessly without interference. Get 7 hours on a single charge and 28 hours with the case.
Anker charging cables, wall chargers, and solar power banks
Never go without power. Get an Anker power strip with a USB-C port, a USB-C to USB-C charging cable, a USB-C wall charger, or even a 10000mAh portable battery charger with a built-in solar panel so you can get power even in the great outdoors.
Anker wall chargers, USB-C cables, wireless charging pads, and more
The sale includes USB-C to USB-C cables for as low as $11, a five-port wall charger with Quick Charge 3.0 ports for just $26, and even an Anker power strip that includes multiple USB ports and AC outlets for $25 off. All prices are good today only.
Anker Roav C2 Pro dash cam black
Has a 145-degree wide-angle lens that can view up to four lanes of traffic. Includes a Stony Starvis sensor and NightHawk tech for capturing everything, even license plates, day or night. Has a 3-inch display and built-in G sensor.
Though this well-reviewed wall charger is equipped with just one USB-C port, it has a 45W output so it can be used with a variety of device types including larger tech gear like laptops. In addition to its USB-C connector, there's also a USB-A port with a 15W output for powering up a second device simultaneously.
Even though it packs the same sort of power as a MacBook charger, it has a 15% smaller form factor making it perfect for travelling with. It also has a folding plug. Unlike previous wall chargers, this one is powered by gallium nitride which generates less heat and allows Anker to make it much more compact.
With so many devices going all-in on USB-C, you can future-proof yourself with this high-performance wall plug and reduce travel clutter at the same time thanks to its USB-A port. If one USB-C port is not enough for you, you can also snag a 2-port version, though that model is only $5 off right now. It's worth noting that neither option includes a USB-C cable so you'll need to use your own or add one to your order.
