The discounted PowerPort 2 USB Wall Charger reaches $8 with this Amazon deal
Keeping all your devices powered up could be a lot easier with a charger like Anker's 24W PowerPort 2. It's equipped with two USB ports so you can power up to two devices at the same time, and today it's on sale for just $8.09 when you clip the coupon on its product page at Amazon. That saves you a few dollars off its usual cost of $11 and brings this USB wall charger down to one of its best prices in history.
Anker 24W PowerPort 2 USB Wall Charger
Power up two devices at the same time with Anker's 2-port PowerPort 2 USB wall charger. It offers 24W of power in total and drops to just $8 when you clip its on-page coupon at Amazon.
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerPort 2 features Anker's patented Voltage Boost technology to charge every device at an optimal rate; that means you'll be able to charge some devices faster without over-charging. Its robust textured casing and premium internal components help this charger last for years on end even after scrapes, bumps, and drops. It's also equipped with a foldable power plug to help it become even more compact when you pack it away. Anker also includes an 18-month warranty with its purchase.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial of Prime to score free two-day shipping with no order minimum. You'll also gain access to perks such as the Prime Video streaming service, exclusive members-only discounts, and much more.
