Apple recently opened up the MFi-certification program for USB-C to Lightning cables and we've seen a surge of vendors eager to get into the fast charging market with their own offerings. UGREEN was one of the first on the scene and it has just released its newest addition, a braided nylon USB-C to Lightning cable, and you can already save on it when you clip the on-page coupon and enter UGREENNL during checkout at Amazon. Combining those coupons will snag you this cable for just $10.49.
Speedy
UGREEN Nylon USB-C to Lightning Cable
Fast charge your iPhone for less with this cable at 29% off. Its rugged design also protects it from getting damaged.
$10.49 $13.99 $4 off
With coupon: UGREENNL
Being MFi-certified means this cable passes all the safety tests required by Apple in order to properly charge your device. Normally, it sells for $14, which is already pretty amazing, and today's price drop is its first discount.
Using it, and a compatible USB-C adapter, you'll be able to charge up your devices super quickly. It's not widely known, but fast charging has been present in the iPhone since the iPhone 8 and iPhone X were released, but it can only be done using a USB-C to Lightning cable and Apple was previously the only provider of those. Using UGREEN's cable with a USB-C adapter will allow you to charge your iPhone from 0% to 50% in 30 mins. Fast charging also works on Apple's newest iPad models like the 10.5-inch iPad Air.
The cable features a rugged braided nylon case with reinforced connectors to avoid tangles and damage from over-bending. As well as supporting fast charging, it also works for high-speed data transfers up to 480Mbps. If you've upgraded to a newer MacBook and don't have a full-size USB-A port anymore, these cables are an absolute necessity. At this price, it's worth grabbing a few just to keep around the house, at the office, and in your various travel bags.
