Source: Fibaro
Best Smart Water-Leak Detectors iMore 2022
Smart water-leak detectors are an essential tool when it comes to home safety. The Fibaro Flood Sensor is a completely wireless option that allows it to be placed under or near potential water leak points and can notify you instantly via HomeKit if a leak is detected. We have gathered the best smart water-leak detectors to help you decide what is right for your needs.
- Best Overall: Fibaro FGBHFS-101 Flood, Water & Temperature Sensor
- Best Security: Ring Alarm Flood and Freeze Sensor
- Best Coverage: iHome Wi-Fi Dual Leak Sensor
- Best Monitoring: Flume Water Monitor: Smart Home Water Monitoring to Detect Leaks & Track Water Usage in Real-Time
- Best Prevention: Moen 900-001 Flo by Moen 3/4-Inch Smart Water Shutoff
Best Overall: Fibaro Flood Sensor
Source: Fibaro
The Fibaro Flood Sensor is a compact, battery-powered solution to keep you informed of any potential leaks in your home. It's also the best smart water leak detector on the market today. The wireless design means you can place it almost anywhere, making it a perfect option to add monitoring where a plug is not available. Simply pair the flood sensor with HomeKit via its built-in Bluetooth capabilities and set it under a sink, near a water heater, or anywhere else that has the potential to spring a leak.
Fibaro's Flood Sensor also supports external wired leads enabling it to reach behind places where the sensor may not fit into. Additional features for the flood sensor include temperature monitoring, which is added as a separate device in HomeKit. Both leak detection and temperature can integrate with other HomeKit devices. This allows tons of automation options, such as turning your smart lights blue if a leak is detected.
Those looking for an easy-to-setup option allows them to set it and forget it can look no further than the Fibaro Flood Sensor. While it may not be the most used smart device in your home, it may be one of the most important if the worst-case scenarios happen. Instant notifications to your iOS devices will allow you to stay on top of any issue that may arise and hopefully help prevent them from becoming a much bigger problem.
Pros:
- Wireless design
- Can be expanded with optional leads
- Also includes a temperature sensor
Cons:
- Expensive
- Works with HomeKit only
- Bluetooth connectivity limits placement
Source: Amazon
Smart home security experts, Ring provides a wireless leak detection sensor that is compact and sleek. The Ring Alarm Flood and Freeze Sensor is a battery-operated solution that allows it to be placed just about anywhere in the home. Plus, 3-year battery life means that it will be working in the background for years to come.
Ring's sensor communicates via Z-Wave to the Ring Alarm system and can be placed up to 250 feet away, ensuring that it will work in the further reaches of your home. In addition to leak detection, a built-in temperature sensor can determine if the area is too cold, which could cause your water lines to freeze and potentially burst.
Pros:
- Completely wireless
- Three-year battery life
- Strong wireless signal
Cons:
- Requires Ring Alarm System
- Does not work with professional monitoring service
- Cannot be extended
Source: iHome
The iHome Wi-Fi Dual Leak Sensor provides two forms of leak detection in a small wireless unit. The iHome's sensor's base has water sensing contacts, and an attached six-foot lead can also determine if a leak has sprung. This allows the Dual Leak Sensor to cover multiple areas with just one device.
Wi-Fi connectivity enables the Dual Leak Sensor to function wherever a signal is in your home. Best of all, the sensor communicates directly to your Wi-Fi router, with no additional hubs or systems required.
Pros:
- Low Price
- Does not require a hub
- Flexible placement
Cons:
- Does not work with HomeKit
- Only integrates with other iHome devices
- No built-in alarm
Best Monitoring: Flume Smart Home Water Monitoring System
Source: Flume
The Flume Smart Home Water Monitoring System is designed to keep you aware of the water usage and flow within your home. A small, compact unit is attached directly to your water meter via an included strap and requires no tools for installation. The water sensor is battery-powered and works up to 1,000 feet away from a separate bridge that you plug in.
Once installed, the Flume Monitoring System will be on the lookout 24/7 for any potential leaks and alert you instantly if a problem is found. Since Flume's device attaches directly to your water meter, you do not have to worry about placement as it measures water flow to determine if any leaks are occurring.
Pros:
- Installs without tools
- Monitors usage trends
- Extra-long signal range
Cons:
- Expensive
- Only provides monitoring
- Is not compatible with all meters
Best Prevention: Moen Flo Leak Detection System
Source: Moen
The Flo Leak Detection System by Moen is a complete, whole-home solution. Attached directly to your main water line inside of your home, Flo can determine the smallest of leaks through Micro Leak Technology. It also provides usage and trend reports, which may help identify ways to conserve water and lower your utility bill.
Unlike other leak detectors, Moen's system can shut off the main water supply to prevent damage if it finds a leak. While professional installation is recommended, this ability alone may be worth the high price tag if it can prevent a flood from happening inside your home.
Pros:
- Instant alerts and daily testing
- Provides monitoring and usage trends
- Shuts off water supply if issue is detected
Cons:
- Pricey
- Does not support HomeKit
- Professional installation recommended
Stop the Leaks
Smart water-leak detectors are a great way to add a little extra peace in mind to your home. Usually operating in silence, leak detectors come to life at the crucial moment where the first signs of water are found. Entirely wireless options can be placed almost anywhere in the home, and whole-home monitoring solutions can be installed to shut off all the water to your home if any abnormalities are detected.
The Fibaro Flood Sensor is the best smart water leak detector and a solid choice for those looking for an easy to set up, set it, and forget it solution. Powerful automations can be created to flash the lights in your home or sound an alarm if a leak is detected thanks to HomeKit integration. Fibaro's sensor also acts as a temperature sensor, and a built-in tamper alarm will notify you if it happens to be moved from its position once set.
Show off your HomePod with the best accessories around
Apple's HomePod is so much more than a speaker. Here are some accessories to take full advantage of everything it offers.
Start delegating your time-consuming chores with these great robot vacuums!
Why spend your time cleaning when you could be resting and relaxing instead? Get yourself one of these great robotic vacuums.
Get peace of mind with these great HomeKit smoke and CO detectors
So you've automated your lighting, your blinds, your thermostat, your dog's feeding schedule, etc. What's left? Well, why not add some smarts to your smoke detector with these HomeKit-enabled options?
