The iRobot Roomba 960 self-charging smart robot vacuum cleaner dropped to this $500 price back in June. Since then, however, it has sold for around $600. This is the lowest price we've seen this year, and it's made even better with how expensive the robot vacuum has been selling for.
Robots are the Future
Along with all the dust and dirt and grime around your home. Plus you can control it with Alexa.
$499.99 $600.00 $100 off
The 960 delivers 5x the power lifting suction of previous iRobot generations. The little robot can map its surroundings using its advanced navigation features, which allows it to clean your home autonomously without getting stuck on furniture. It can also clean up pet hair well thanks to a three-stage cleaning system that also helps it pick up allergens and dust. When the battery gets low, the 960 will return to its self-charging station on its own and keep going until the work is done. Use Amazon Alexa or Google Assistant to give it voice commands. You can also use the iRobot Home app to create schedules and monitor sessions.
