If you have jailbroken your iPad with the recently released Jailbreakme exploit and use the official Apple Camera Connection Kit, you may have noticed that it no longer works. Apparently Comex knows all about the problem and will be issuing a fix for it today. The fix will enable you to use the Camera Connection Kit as normal and will also address some packages from Cydia that have had problems too.
According to Comex, the fix will be in the form of a download from Cydia; if you are already jailbroken. We assume then that it should be part of any new jailbreak in the future; but don’t quote us on that!
[@comex]
