Best HomeKit Light Bulb Sockets iMore 2022
The best HomeKit light bulb sockets are an easy way to squeeze a little more out of your current bulbs. These sockets add remote control of your bulbs through the Home app, Siri, HomeKit scenes, and automations. Plus, they can also add dimming if your existing bulb supports it. Make your lighting smart with the best HomeKit light bulb sockets on the market today.
- Color it: iDevices Socket
- Cost effective: Incipio CommandKit Wireless Smart Light Bulb Adapter
- Highly compatible: iHaper Smart Light Bulb Socket
- Slim fit: Terncy Smart Light Socket
Staff FavoriteThe iDevices Socket supports bulbs up to 60 watts, and can handle incandescent, CFL, halogen, and LED lights. This socket pairs directly with HomeKit via Wi-Fi, and once set up, your existing bulb is ready for remote control and more. This socket also has a nifty LED ring around its base, allowing it to function as a nightlight.
Incipio's CommandKit Wireless Smart Light Bulb Adapter is a low-cost way to add HomeKit to your current bulbs. Don't let the low price fool you, though; this dimmer supports all of the goodies that come with HomeKit. Dimming support for incandescent bulbs is also available, and it even works outdoors.
The iHaper Smart Light Bulb Socket works with all of the major smart home platforms, HomeKit, Alexa, and Google Assistant. iHaper's socket connects to your home network via Wi-Fi and doesn't require an extra hub. This socket also supports all light bulb types, up to 25 watts maximum.
The Terncy's Smart Light Socket sports one of the thinnest profiles around, making it easier to position within your light fixtures. This slim socket operates via Zigbee and requires a proprietary hub, but the protocol provides quicker and more reliable connections. The Terncy socket also has a handy on-device power switch, perfect for those times where you just want to push a button.
Power up
the best HomeKit light bulb sockets are the perfect way to reduce waste by adding smart home connectivity to your existing bulbs, so you don't need to go out and buy the best smart lightbulbs. These adapters provide access to remote controls, automations, and Siri, in an easy to install package. The iDevices Socket not only adds the smarts to your bulbs, but it also includes a colorful LED ring around its base, allowing it to work as an indicator light or a nightlight.
If you are looking for the lowest price around, Incipio's CommandKit Wireless Smart Light Bulb Adapter is the one for you. This affordable socket is cheaper than most smart bulbs and doesn't skimp out on features.
Need the absolute thinnest socket around for your light fixture? Then check out the Terncy Smart Light Socket. This socket provides all of the awesome HomeKit functionality in an incredibly compact form factor.
Show off your HomePod with the best accessories around
Apple's HomePod is so much more than a speaker. Here are some accessories to take full advantage of everything it offers.
Tired of using a light switch? Then you need a HomeKit motion sensor!
Ready to make HomeKit even more magical? Put the "auto" in "home automation" with the best HomeKit motion sensors!
Hey Siri, make it rain with the best HomeKit sprinkler controllers
HomeKit sprinkler controllers make it easy to keep up with your lawn watering needs thanks to automations, scenes, and, of course, Siri. Take your watering game to the next level with the best HomeKit options around.
